Question about Bionaire BH3900-U Oil Filled Radiator Heater
Switch bad? Our Bionaire Bh3900 u has a control switch for off, low and high.  The switch no longer clicks in at these settings.  With a little adjustment, you can get the heater to come on in between these two settings, but it is only working in the 'low' mode.  Can the switch be repaired by my husband?  The item is out of warranty.  Obviously the heater function is still operable.
  • 2 more comments
  • Anonymous Feb 11, 2008
    where cah I get a new switch?
  • sweetlewb Mar 03, 2008
    I had the same problem. When I took the switch apart, the wire for the 'high' setting looked like it had been burnt. I emailed Bionaire and am going to try a small appliance repair shop this week. If anything helps, I'll be sure to repost.
  • tnriver
    tnriver Nov 16, 2008
    The off on switch appears to have burn up inside...need new switch...anyone know where to fine on? Thanks alott...need heat!! Janice
  • mekman Feb 21, 2009
    switch and wires burnt need upgrade!!!
  • 45 Answers
The switch has gone bad. the switch cannot be repaired but can be replaced
Posted on Jan 12, 2008
SOURCE:
Bionaire heater sometimes turns on at very low intensity and just kind of chugs along as the yellow button flashes. It works fine just wondering why it does that
Amazon.com - Bionaire Heater with Rotating Grill ...
www.amazon.com > ... > Space Heaters
Amazon.com, Inc.Amazon.com - Bionaire Heater with Rotating Grill, BFH2242M-SM - Space ... The ultraquiet Bionaire® Heat Circulator with Rotating Grill circulates warm air ... High-intensity, sun-like warmth, Gentle heat, Medium intensity, whole room .... When temperature reaches what you have set it to, the heater turns off and sometimes.
Bionaire Office Heater with Worry Free Motion Sensor
www.amazon.com > ... > Heaters & Accessories
Amazon.com, Inc.
Rating: 4.4 - ‎71 reviews
Amazon.com - Bionaire Office Heater with Worry Free Motion Sensor - Space Heaters. ... Heat turns off after 30 minutes of no motion detected. ... If you place it under the desk, your feet will be very warm, but not so much the rest ... CONS: The High setting gets too hot sometimes, while the Low setting doesn't get hot enough.
Bionaire® Electric Fireplace Heater BEF6500-UM - Bionaire
www.bionaire.com/bionaire-site.../bionaire...heater/BEF6500-UM.html
The Bionaire® Electric Fireplace Heater provides the ambiance and warmth of a ...Flame Intensity; 12 Hour OFF Timer; Free Standing or Wall Mountable; 2 Heat .
Jan 30, 2016 | Bionaire Heating & Cooling
Needs a new on off switch
Did you ever find your part? I need the same thing.
Feb 03, 2014 | Bionaire BH3900-U Oil Filled Radiator...
Click headlights to low beam and no lights work on high beam
I'm not sure exactly what your problem is. When you "click" your lights to low beam, your high beams should not work. But if your low beams work when you "click" them on, but your high beams don't work when you "click" them on, you either have a blown fuse, bad relay or high beam elements burned out on both lamps. (Not so unusual) Possibly a bad "dimmer" stalk switch or bad wiring, too, but a little less likely.
Sep 05, 2011 | GMC K1500 Cars & Trucks
Our hunter fan won't work on high speed any longer, low and medium speed work fine, when clicked on high - it only goes at medium
Sounds like the variable speed switch may be worn out.
You should be able to purchase replacement switch at the local home depot- type store in the electrical supplies.
Trying to get an exact match to replace may be a bit difficult, but a similar 3 speed switch should work just fine.
Jul 18, 2010 | Hunter Ceiling Fan Control Switch
Ceiling fan stuck on high
I found out that the capacitor and switch is shortened. I un-shortened, and it got to low, mediium, and off.
Apr 27, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Heater blower went out?
Either the blower went bad or the heater relay went bad. This does not sound like a heater core problem unless you where smelling a SWEET smell when it was running.
May 16, 2009 | 1993 Toyota 4Runner
Bionaire BH3950 Does not heat
I'm not an expert, but I have two of these units that are working fine.
The on/off switch (the top switch) has a light in it that illuminates when the heater is on and heating. If this light comes on and there is no heat, then the element is probably burned out.
The heater has a safety switch that prevents the unit from working if it is not upright. If the heater was stored for any length of time on its side, the safety switch might have stuck in the off position. Unplug the heater and with the heater upright, try shaking it or slapping it firmly with your hand to se if this fixes the problem.
If none of this works, then as sunmasc says, the thermostat is bad.
Jan 12, 2008 | Bionaire BH3900-U Oil Filled Radiator...
Bionaire BH3900-U Oil Filled Radiator Heater Logo
375 people viewed this question
Top Bionaire Heating & Cooling Experts
Richard McDermott
Level 1 Expert
Dennis Webber
Vernon Taylor
Are you a Bionaire Heating and Cooling Expert? Answer questions, earn points and help others
