Question about Sony CDX-M800 CD Player
Lost function of remote and front panel buttons
After starting the car the other day, I lost all remote functions and all front panel functions except for power and CD eject. Anyone with a proposed fix?
  • 111 Answers
It seems like the ribbon cable,the one connects the face to the main board is damage.
I don't know if you can replace it by your self,because you need a little bit of experience on stereo repair,but you can try.you can order the part from pacparts.com
Part number 168795211
Posted on Dec 04, 2007
SOURCE:
How to use functions of tv without the remote
Unless there are buttons for what you want the best bet is bite the bullet and get an original remote---not always easy depending on the brand but the best way to go.
Do not waste money on a Universal as if it even programs for your set it will be missing key or essential functions the original had.
Dec 06, 2012 | Televison & Video
Tip
Lost Remote Control? Here's a way to help.
So you have lost, or, your remote doesn't work? You can't "Do anything" without it.... Right.... NO Wrong... ALL TV sets have a number, usually about 5 - 6, "Buttons" on the side, front, somewhere. usually close to the "Power ON" switch. Now these "Buttons" will perform nearly all, if not all, of the main functions of your "Remote" They WILL be marked, MENU, +, -, <, >, & OK or ENTER. Now you simply have to depress each button to access the "Functions" you want. One button WILL control the "Function" say Channel, and the <, >, will Go UP & DOWN. This is the same for everything. So one button will make it, say go UP, another will make it,say, go DOWN. Repeated presses on the "Function" Button will scroll through the "Functions" IE: Channel, Brightness/Contrast, Selecting Inputs, once "Selected" another "Button" will move the "Selector" through to the Bottom & another will scroll it back Up, sometimes the ONE button will simply continuously scroll "right around" Of course have a look in your manual... you know that paper thing you shoved away in the cupboard... This will explain it all. ALL TV's and devices that use a "Remote" are ALWAYS able to "Control" the MAIN functions of the unit,via keys on the actual unit itself. So don't despair, just spend a bit of time learning your "Buttons" that way even if the "Remote" does go walkabout, or the batteries go flat, or it just stops working.. well now you can still have complete control.. the only draw back is you will have to get put of your seat to do it. A small price to pay?
on Feb 13, 2010 | Televison & Video
Ferguson F1905lvd t/v no remote control and need to re/tune
As there is no Menu button on the front panel of your TV, to perform an auto tuning function, you must have its remote control. Without remote control, it is impossible to get in to this menu option.
Jun 12, 2012 | Televison & Video
Turn on pip wiithout remote
If your TV has a Menu button on its front panel, enter its Menu widow, surf through, come to wards picture control window, and make PIP function OFF. If it has no such button, you must have its remote control to turn it OFF.
Jun 07, 2012 | Televison & Video
My child lost the remote control and I don't know
HI
What a shame, look for a button/knob/touchpad on the front of the television set.
There should be buttons for all the major functions of the TV.
Down to the right.
I hope you will find your remote control.
All the best
kolbrun
Feb 20, 2012 | LG Televison & Video
I pushed a button and lost all sound, what should i do? is there a reset button to get going again?
The "MUTE" function on your remote control has been activated.To deactivate the "MUTE" function, simply press the "MUTE" button on your remote control. (Make sure the volume control is turned down to avoid damage to your system.) If you misplace or lose your remote control, you will have to purchase a new remote control unit, as there is no duplicate function on the front panel of your stereo. Unplugging the stereo will not deactivate the muting circuit, as the microprocessor "remembers" if the muting circuit was active prior to being turned off or unplugged. If you need to purchase a remote control, you may order one directly from our parts office.
Dec 16, 2010 | Yamaha HTR-5930 Receiver
I have lost the manuel and remote for my GE49GW948
Best thing to do is to buy a universal remote - preferably RCA/GE brand since it will work without programming.
You should also be able to get to the autoprogram function of the TV by using the front panel buttons.
Oct 19, 2009 | GE 46GW 948 46" Rear Projection Television
Sony DAV DZ230 Child Lock
hello You can deactivate the buttons on the unit
(except for "/1) for preventing misoperation,
such as child mischief (child lock function).
When the child lock function is activated, the
buttons on the unit are locked and “ ” lights
up in the front panel display. (You can operate
the system by using the remote.)
Note
•When you operate the buttons on the unit while the
child lock function is on, “CHILD LOCK” appears in
1 Press SYSTEM MENU.
2 Press
X/x repeatedly until “CHILD
LOCK” appears in the front panel
display, then press or
c.
3 Press
X/x to select a setting.
The default setting is underlined.
• “OFF”: Child lock function off.
• “ON”: Child lock function on.
4 Press .
The setting is made.
5 Press SYSTEM MENU.
The system menu turns off.
Tip
• You can activate the child lock function by pressing
x for more than 5 seconds (“ ” lights up in the
front panel display).
To cancel, press x for more than 5 seconds so that
“ ” disappears from the front panel display.
Deactivating the Buttons
on the Unit good luck
shaun
Sep 12, 2009 | Audio Players & Recorders
ILO-32HD
Normally this is a good indication of a stuck button on the set. With the set off, try working each of the control buttons. You should be able to feel teh button engage. If one feels like it does not work, that is the likely culprit and it should be replaced.
Let me know your results.
Dan
Sep 07, 2008 | Televison & Video
Sony CDX-M800 CD Player Logo
147 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
