Question about Refrigerators
Water Dispenser Problems
My refrigerator is only two years old, and the water dispenser/ice maker system is acting very strange. My refrigerator has one of those metered water dispensers that tells you exactly how many ounces are being dispensed. It worked fine until yesterday, now if it says it dispensed 8 ounces, it really dispensed 4 ounces, and the other 4 ounces seem to go into the ice maker fill tray. This causes the ice maker to overflow and water leaks all over the inside of the freezer. The opposite is also true, when the ice maker fills water also comes out of the water dispenser.
I visually checked the water pressure in the water line and it looks good. I tested the dual water valve and got 260 ohms on the leads to both solenoids (the water dispenser and the ice maker). I then had my wife push the water dispenser paddle and I tested the voltage. Interstingly enough, I got 120 volts across the water dispenser contacts and 86 volts accross the ice maker contacts. Since the ice maker was not supposed to be filling at this time, shouldn't I have read 0 volts instead of 86? I read on your board that someone had a similar problem and it was a diode in the wiring harness. Do you think I have the same problem? What parts would I need to fix it and could I fix it myself?
Thanks
  • 3 more comments
  • lg frid Dec 23, 2007
    the water dispenser is running very slow.
  • tw104 Dec 24, 2007
    Our Whirlpool water dispenser valve stuck in open position and started flooding kitchen. Luckily enough people were present to move refrig. and shut off main water valve in back! I contacted Consumer Product Safety Commission.
  • Anonymous Mar 06, 2008
    water is running slow. I changed the filter as directed and its still running slow?
  • Anonymous May 03, 2008
    when my ice maker is filling with water, water also comes out of the water dispenser
    when the ice maker is filling with water, water also comes out of the water dispenser, can I fix this myself?
  • 1314 Answers
SOURCE: Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Posted on Jan 02, 2008
22yooper
  • 828 Answers
SOURCE: frigidaire water leaks
I suspect that when the water valve was replaced, that the plug's were reversed that provide the power to the valve. Exchange the two plugs on the water valve and you may find the problem is fixed.
Posted on May 26, 2008
tborn6
  • 700 Answers
SOURCE: Water dispenser stopped working.
if your ice maker works fine then its going to be your solinoid valve thats bad oin the dispenser.
Posted on Apr 05, 2009
SOURCE: Ice maker won't fill with water
replace selenoid valve
Posted on Aug 20, 2009
  • 291 Answers
SOURCE: Fridgedair R134a ice maker water wont fill.
Your icemaker send the voltage to the water valve as it cycles through its ice drop. Pull your icemaker out, and test the wiring it was plugged into for continuity to the water valve, usually you will only have one colored wire that has continuity. Your white wire is usually your nuetral and as long as both wires are ok, then replace your icemaker or your icemaker module if it has one. You have a very good parts house on Oahu called Reliable Parts, Take your icemaker in if you live on Oahu, or call them with your parts number if you are on the Big Island. I worked on Oahu for 15 years. Good Luck Appliance Specialists
Posted on Dec 14, 2009
Testimonial: "Thanx very much I hoped it wasn't the whole ice maker, yet I kinda figured, but being on Oahu it's no biggy. Jeff."
It's not making ice. Not sending water to the ice maker. I replaced the filter this morning. Water is dispensed for drinking , but not for the ice maker.
I just replaced the water valve because my water dispenser in the door kept dripping. Google parts for your model and put in water valve. It will cost around $80 for the part. My sic year old did most of thr reacement after watching an online video.
Aug 22, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
Our brand new 3 door 25' LG has stopped producing ice. The switch is ''on'', and water dispenser works. The motor operates to send either cubes or crushed ice out the dispenser, but NO ICE. What do I look...
LG has problems with there ice makers. if is less than a year old it is under warrenty--even if you dont have a reciept. sounds like the ice maker needs replaced. i have replaced several that were less than a year old.
Oct 28, 2009 | Refrigerators
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Kenmore Side by Side Refrigerator Model #106.50544001
It's time to replace the dual water inlet valve (the part the water line connects to). A bit of sediment or other fine object can get in the seat or the material itself can deteriorate and allow a tiny amount of water to pass up to the icemaker.
Jan 04, 2008 | Whirlpool GR2SHWXPB 21.7 cu.ft. Top Mount...
Refrigerators Logo
289 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
