Question about HP LaserJet 3330 All-In-One Printer
Bulb never lights up,
On power up, the panel says scanner bulb warming up, but light never comes on. Sometimes it gives a 79 error
  • 56 Answers
Hi The option you have is to check and make sure the connection between the formatter and scanner formatter are properly seated. The 79 error you are getting means you should try and do a firmware upgrade it could be giving you a problem and more than likely fix the issue.
Posted on Dec 03, 2007
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
Hp fax model 3330 is broken . At first it was very slow to warm up bulb and finally it stopped working all together and the screen says scanner error power on - off. The cancel light is blinking and...
You are correct with your diagnostics, he problem is caused by dirty optics. The mirrors in the scanner have dust, lint or smoke on them. When the scanner powers up it tries to calibrate itself and waits for the bulb to warm up so the light output gets to a certain level. With the dirty optics the scanner never gets enough light so it thinks the scanner is still warming up and so it waits for the light to get brighter. After a few minutes of waiting and not getting the correct level of light it gives the power off message. We have a dis-assembly and cleaning guide with step by step instructions posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ This procedure takes about 30 minutes to complete but it should et you back going again.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 15, 2010 | HP LaserJet 3330 All-In-One Printer
My 3330 says scanner bulb is warming up then it gives me a error 79 message no ,matter how many times i restart it
The error 79 on that machine means that the scanner assembly has failed to align/calibrate. Could be due to a bad calibration strip on the scanner glass, have you ever sprayed glass cleaner directly onto the scanner glass? If so this can stain the calibration strip and render the scanner useless. It is probably best to have the machine serviced by HP.
Feb 05, 2010 | HP LaserJet 3330 All-In-One Printer
Engine light on
The check engine light comes on and stays on when a problem is detected by the self diagnosis system of your vehicle. Generally, the problem is in the emissions or something that is affecting the effectiveness of the emissions, but other causes can trigger the light to come on, too. To determine the cause, the vehicle will need to be taken to AutoZone or a shop that has an OBD2 scanner, or for 1995 and earlier models, an OBD1 scanner, While a scanner will not give you the magic answer, it will give you a code that narrows down the problem area.
A flashing check engine light is an indication of a severe misfire or problem that is likely to harm your engine. Immediate diagnosis and service is needed.
Some specific causes for the light to be on are:
Gas cap left off, not tightened, not installed correctly, or needs to be replaced
02 sensor
Engine misfire - error might clear itself after 3 complete warm-up cycles; not restarts, but warm-ups
At start up for a bulb check - Should not stay on
Problem in the emission system, including clogged exhaust or the catalytic converter not functioning properly
Dirty/clogged air filter
Dirty MAF sensor
Jan 08, 2010 | 2007 Ford Freestar Limited Minivan
Hello, Pls tell me what Happend when my engine light on bord is turned on.
02 sensor
Dirty MAF sensor
Jan 08, 2010 | 2002 Hyundai Accent
ENGINE LIGHT COMES ON WHILE DRIVING MERCEDES BENZ C230 2005 TOOK CAR TO DEALER AND THEY FIXED TO THERMS & COOLANT SENSOR 2DAYS LATER AFTER PUTTING FUEL IN ( HIGH GRADE) LIGHT COMES ON I DON' T WANT TO...
02 sensor
Dirty MAF sensor
Jan 08, 2010 | 2005 Mercedes-Benz C-Class
Hp 3055 no lingt on the control pannel, no power up, no warm up, it just like pluck off machine. nothing comes on.. what is the problem? anyone experience it? please give me a hand... thanks
Hi benkoh76: Here is your problem. Troubleshooting checklist Follow these steps when trying to solve a problem with the all-in-one. Step number Verification step Possible problems Solutions 1 Is the power on? When the all-in-one is connected to a grounded power source and is turned on, the control panel shows Hewlett-Packard with moving cursors indicating that the firmware code is loading, and the main motor rotates for approximately 45 to 60 seconds. When the firmware is done loading, Scanner bulb warming up might appear on the control-panel display, and the scan head moves back and forth for 10 to 15 seconds. If you lift the scanner cover, you will see that the scanner bulb is lit. Near the end of this time, the ADF motor turns on for about two seconds. No power as a result of a failed power source, cable, switch, or fuse. 1. Verify that the all-in-one is plugged in. 2. Verify that the power cable is functional and that the power switch is on. 3. Check the power source by plugging the all-in-one directly into the wall or into a different outlet. Motor does not start. 1. Verify that the all-in-one is plugged into a working electrical receptacle. 2. Verify that the print cartridge is installed correctly. Follow the instructions on the control panel to remove and replace the cartridge. 3. Verify that the top cover is closed. ADF motor does not start. Open the ADF cover and remove any orange shipping tape inside the ADF. Verify that the ADF connector is connected correctly to the scanner. If the ADF motor still does not rotate, replace the ADF. Scanner bulb does not light. If the scanner bulb does not light, verify that the wire-harness connectors from the scanner to the formatter are connected correctly. If the error persists, replace the following components one at a time until the problem is resolved: scanner assembly, formatter. Hope this helps
May 30, 2009 | HP LaserJet 3055 All-In-One Printer
Canon Scanner 5000F fails when adjusting lamp before scan.
Have the same problem. Suspect a lamp problem but cannot find any info/help to check lamp or to replace it
May 27, 2009 | Canon CanoScan 5000F Flatbed Scanner
Scanner error 6
Scanner errors are as follows for that model:
Scanner error #
1 = dark find
2 = LMW temp find
3 = bulb warm up from off
4 = bulb warm up from coarse
5 = cal label find
6 = doc original find
7 = LMW final find
8 = cal label find after scan
9 = cal label find prior to standby
10 = doc original find prior to standby
11 = bulb warm up from standby
I would see if there is an original on the flatbed glass (platen), or if something is obstructing the scanner view.
If the error persists, replace the scanner
assembly or the formatter pcb
Apr 22, 2008 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 3330 All-In-One Printer Logo
150 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
