Question about Alcatel SpeedTouch Pro (3EC18804CCAA) Router
Cant get onto configuration page of router as says authentification failed
I keep losing my internet connection and am trying to get onto the configuration page to reconfigure it as this worked last time, but it keeps saying authentification failed although i know im using the right password, AOL cant help and say it may be broken, although right now i have a connection?
  • Anonymous Mar 22, 2014
    lost authentification of Asus tablet but forgot password so how can I authentificate properly
  • 556 Answers
In the simplest sense could this be an intermittent wire issue -- evidenced by depending how it is moved it disconnects or reconnects? Secondly if this is your device and not AOL's or someone else's like your ISP AND YOU KNOW THE ENTIRE CONFIGURATION CONTENTS.
REPEAT AND YOU KNOW THE ENTIRE CONFIGURATION CONTENTS. You may be able to find a user guide with reset instructions to get access to the configuration again.
Posted on Dec 06, 2007
SOURCE:
Hi i Just bought dlink 600 i am using compaq and has iphone and internet tv all of them cant connect by wifi my compaq can only connect with a cable. on my tv it says internet connection failed. and btw cm...
ok first prep. we need to configure your router. to do that we need your compaq laptop directly connected to the dlink via ethernet cable. after securing the connection, try to open a browser, whether internet explorer or mozilla firefox. go to the address bar and type in, 192.168.1.1 it would ask you now for a username. username is " admin " password is " password " if it wont let you in, try "admin" for password. if it still cant, try to live it blank and just click on login. it would take you now to the dlink router page. there you can configure your wireless connection and set your network name. make sure to click apply settings after configuring it. then try to check your wireless connectivity again. this should work.
Sep 02, 2011 | D-Link DIR-600 Router
Cant rember password
Your wireless router is prompting you for a password in order to log onto your network. If you do not remember your password, you can reset the routers' configuration by holding down the reset button on the back of the router, and you can then use the default user name and password to change the settings. HOWEVER, you will lose all of your network settings so if you have multiple devices connected via wireless,they will also have to be reset.
If you need help re-configuring your router, visit the router manufacturer's web page. There should be a tutorial to walk you through the process.
If you happen to have a Linksys wireless router, here is their page: http://www.wikihow.com/Reset-a-Linksys-Router
Sep 06, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Tried to secure my wireless connection, but all I did was stop my UTStarcom adapter from getting internet access. I now can't log onto my UTStarcom router setup page anymore. Can't I just reset this? I can...
Symptom You are trying to access the Belkin router’s Web based Configuration page and you are not able to do so. You can access the Configuration page from any computer behind the router.
Resolution To address this issue, follow the instructions below:
  1. First check for the physical connections between the computer and the router. There should be a cable (cat5 or above) running from one of the LAN port of the router to the Ethernet card in the computer.
  2. If the computer is wireless, it should be associated to the Router/AP.
  3. Check for any firewalls (Mcafee, Norton Internet Security) on the computer, which should be disabled.
  4. Check for an IP Address on the computer in the range of the router i.e. 192.168.2.x (x can range from 2 to 254). The router also assigns an automatic IP address to the computers in the range 192.168.2.x (x can range from 2 to 100). For instructions on how to check the IP address on the computer, Refer to Article 13.
  5. If you are not getting an IP Address on the computer from the router you will need to manually assign an IP Address to the computer.
  6. You also need to restore the Internet Explorer browser to its default settings.
  7. Go to Control Panel and click Internet options. Select the Program Tab and click on Reset Web Settings.
You should be able to get the router's configuration page if the above instructions are followed in order.
Cause You not being able to logon to the router's configuration page could be due to the following reasons:
  1. The computer is not able to establish connectivity with the router (wired or wireless). This can happen due to physical reasons E.g.: Improper cabling, bad cable, and no wireless signals.
  2. The computer not getting an automatic IP address from the router (DHCP ** assigned).
  3. Firewalls (Mcafee, Norton Internet Security) on the computer blocking the communication between the computer and the router.
  4. Improper browser settings (Internet Explorer)
** Dynamic Host Configuration Protocol
Summary The Router is a configurable device and you can manually log into the router’s configuration page to set its various operating parameters like connection type, security features and options to update the router’s firmware.
Jun 22, 2009 | Belkin (F5D7231-4) Wireless Router
Cant connect to the internet with linksys wrt160nv2
if this is DSL connection then you have to configure your modem before you connect router
follow this
first disabled wireless on your modem/router
.1) Turn off DHCP on your modem/router I am assuming this is verizon westell
2. Configure the first VC port to Bridge-Bridge mode
3. Keep hitting "apply" in the windows until the 7500 reboots
4. Plug the "Internet" port on the linksys to one of the normal ethernet ports on the modem /router
5. Turn on the Netgear and wait for the green Internet light to go solid
good luck if this does not work provide more info on your setup
Jun 12, 2009 | Linksys WRT160N Wireless Router
Keep losing internet connection.
The simplest solution is usually to switch from eNet's management to Windows' Wireless Configuration Utility. Other than that, solving the problem would need much more detail, such as the router type, the distances involved, the router's antenna setup, the other equipment in the are and any intervening obstacles.
Apr 22, 2009 | Acer Computers & Internet
Cant connect wireless laptop
Hey folks, try the following things. Hope it helps !
1. Connect the cable from your modem into the Internet port of the Linksys router.
2. Reset the router with the reset button for 30 seconds when the router is ON.
3. Turn the router and the modem OFF.
4. Turn the Modem On first, wait for 10 seconds and than the router.
5. Your Internet should work from the computers connectedto the router.
6. If not open the setup page of the router by typing 192.168.1.1 in and browser, the default password is admin.
7. In the setup page, below setup tab, the 3rd subtab is MAC Address Clone, Click on that and click Enable and click Clone the MAC Address.
8. Repeat Steps 3 and 4.
For more info on linksys devices, you can try these links :
http://linksysfirmwares.googlepages.com/configurations
http://linksysfirmwares.googlepages.com/wirelesssecurity
If you want to configure the Wireless on the router :
Click on the Wireless TAB, change the name [SSID].
  • Connect the computer to the router.
  • Open the setup page. Default password is admin.
  • Change the channel to 11-2.462 GHz.
  • If you want to enable wireless security, go for WEP 64 bits.
Feb 03, 2009 | Linksys WRT160N Wireless Router
Can't connect to internet wired or wireless with wbr-2310
Disable the IPV6 and use the IPV4 then try accessing the configuration page of the router and configure the Internet Settings
Jan 27, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Linksys wireless-G router configuration on PPPoE internet connection
Connect modem to the internet port of the wrt54g
Connect pc to port 2 of the wrt54g
Reset the wrt54g, push reset button for 30seconds with the power on, uplug the power for 10 seconds
Open internet explorer, type 192.168.1.1, you will be asked to login, no username, password is admin. This will take you to the router page. On the page you will se AUTOMATIC CONFIGURATION DHCP, change that to PPPOe, enter your broadband username and password. Click save settings at the buttom of the page. YOU WILL ONLY GET CONNECTION IF YOUR USERNAME AND PASSWORD IS CORRECT.
GOOD LUCK
Mar 14, 2008 | Linksys Wireless-G Broadband Router
Open Questions:
See all Alcatel SpeedTouch Pro (3EC18804CCAA) Router Questions
Computers & Internet Logo
166 people viewed this question
Top Alcatel Computers & Internet Experts
Thomas Perkins
Thomas Perkins
Sameer Raut
Sameer Raut
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
