Advanced multichannel power amplifier M-770
The sistem when is on blow a fuse, but when i remove a relay the sistem can be on and the fan works, but the sound is in and out.
  • ram_chhetry Dec 12, 2007
    The relay sounds as if it is controlling the "mute" circuitry. If you power down the relay there is no power to the speakers. When you pull it out it is the same thing as putting it in the open position.
    Just for giggles, leave relay in, before turning on, unplug your speakers, volume all the way down. Now "mute" the device. first plug the speakers in, if fuse is not blown, try adding a little volume.
    With the speakers and volumke down, there is little or no current dfrawn from the amplifier section. If the device blows a fuse this time, I suspect the amplifier control voltage circuitry is bad.
    If blown when attaching the speakers, susoect the amplifier circuitry.
    Of dourse this does not take into account a good ol' short on the board. This would just mean that the short is AFTER the relay or there is a possibility that the relay control circuit is causing this.
    There are multitude of diagnostics for a pre-amp/amp combo and either way, if your not a technician, it needs to be taken some place for proper diagnostics.
    Scholar:
  • 70 Answers
Posted on Dec 04, 2007
SOURCE:
How do I fix my m-770 amplifier fromm blowing the 6.3A 125v fuse
There could be a short in one of the wires or within the amplifier itself! Check the speaker wiring first!
Dec 02, 2014 | Car Audio & Video
Fan not working...my car is overheating
The fuses are located in the fuse box under the hood, but could be the fan motor too, check if you have power at the motor
Mar 28, 2013 | 2004 Pontiac Grand Prix
2006 Vauxhall Vectra 1.9 cdti 150, The internal heater fan is stuck on. anybody know were the relays are for this.
check the temperature sensor in the head ,i would imagine the relay is in the power distribution box under the bonnet but which one ? cant say i have done one as yet to know
Apr 28, 2012 | Vauxhall Vectra Cars & Trucks
Had a radio installed it flicks or pops frm time to time but this maybe causing my fuse to pop and my car wont start. Had put a relay switch on about a month ago.helppp
Hi.
If there is popping sound and the fuse blows when the radio is flickering, then it is usually a short in the stereo wiring. The short results in excessive power draw and blows the main fuse. The radio must be removed to check the wiring behind. In some less common case the radio itself may be shorted inside becuse a defective PSU. If you have installed an amplifier check also that the problem is not the amplifier ordinary power draw, in that case the problem is fixed installing a capacitor in the amplifier power wiring.
Aug 06, 2011 | 1993 Acura Vigor
Pioneer power amp m-770 keeps blowing the 6.3 amp fuse what could be wrong?
Suspect an overload in the power supply or audio output stage.
Power supply culprits include transformer, the big capacitors, diodes, bridge rectifier, voltage regulator etc.
Audio culprits are anything on the heat sink(s).
Look for burnt, damaged parts too, anything running very hot!
Follow the circuit from the fuse see where it takes you too start.
Nov 05, 2009 | Pioneer Audio Players & Recorders
The power protection kicks in when I turn up my radio volume
ground wire connection or possibly amp is turned up to high when an amp is turned up all the way it starts pushin dc voltage also it could burn out the internal battery check all connections and settings after that make sure subs arent begining to blow a sub that starts to blow kicks of the amp hope this helps
May 21, 2009 | Sony Xplod 500W Bridgeable Multichannel...
Radiator fan
You should check the 30 amp "RDI" fuse and the 7.5 ECU-IG fuse. Both fuses are critical to the operation of the fan system. The RDI fuse sends power to the fan #1 relay. The A/C amplifier turns on power to the fan #1 relay, this is why your fan works on A/C.
Now, with no cooling fan under "normal conditions" (A/C off), you need to have a good fan #2 relay, and a good water temp switch. This switch is on the engine, near the thermostat housing (I think); with a single plug, with a white with a blue trace wire going to it. Remove this wire from the sender, and jump it to ground (anywhere on the metal of the engine) with the key on (engine OFF). If the fan starts, you need a new water temp sending unit. If not, then consider a new fan #2 relay. This system is pretty simple.
Sep 24, 2008 | 2002 Toyota ECHO
AC compressor not engaging
Hi, you should never bypass the compresor because it may cause damage to the sistem including the compresor,even if the sistem is charged if it gets a little low it may prevent the cluth to engage to prevent damage ,be sure that you have the proper freon presure.also check the ac relay and the fuse.....good luck
Jul 21, 2008 | 2000 Ford Mustang
103 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
