Power problem PAVILION zv5000 (AMD) sn:CND5190R9W.
Good Afternoon,
Power adapter is working well (voltage checked). Jack connector looks ok. When the power adapter is pluged in, it is not charging the battery at all. System (Windows xp) does not see that power is coming from the pluged power adapter. It says that "Source of power is: Battery". The battery is dead. After half a minute the system is shutting down itself with the cling noise coming from the mother board area.
Is there any possibility to recover from this situation without replacing the main board? Do you have any suggestions to rectify the problem? Notebook is 2 years old.
Thank you very much.
Tomek
polishsails@hotmail.com
  • Computers & ... Master
  • 1,113 Answers
Yes, I have found that the solder joints on connector terminal on the motherboard become unstable/dry/cracked after a period of time, t seems they are not strong enough to cope with constant movement of plug
Motherboard can be removed and joints on base of power adaptor connector on MB resoldered, once again restoring connectivity from power adaptor plug to mainboard.
Use a moderate temp soldering iron.and thin solder and redo solder joints on power adaptor socket.
Posted on Dec 04, 2007
HP dv6000 laptop not charging problem, adapter, battery and power jack looks like it works fine
If your battery, charger, and DC Jack are ok, then the most common problem is the surface mount transistors on your HP's main board called MOSFET's. They are small 30V N channel 8 pin components soldered to the main board. The boards also have transistor circuits which switch back and forth between a charging and discharging state. However these rarely ever fail. The MOSFETS fail because of the thermal loads which they must endure. Although some notebooks (like the Gateway I'm currently on) have a DC jack which serves dual purpose of supplying DC 19V AND connecting/disconnecting charging circuit. However your HP dv6K does not.
However it's worth mentioning that these models have had all sorts of problems...most notably poor thermal design to begin with that usually creates solder connection problems with the main chipset especially on AMD models. Good luck.. :)
Mar 27, 2013 | HP Pavilion DV6500T Notebook
Pavillion zv5000 won't boot
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
Nov 13, 2012 | HP Pavilion zv5000 Notebook
HP Pavilion DV2000 will not start when power button pressed
Could be a bad;
1) AC adapter (Charger),
Or
2) DC Power Jack, (Jack that the AC adapter plugs into on the laptop),
Or
3) Power On switch, (Power Button Board),
Or
4) Display Lid Switch Module,
Or
5) Power MOSFETs on the motherboard,
Or
6) Ceramic Capacitors on the motherboard.
1) AC adapter:
General example,
http://www.amazon.com/Original-HP-65W-Adapter-Pavilion/dp/B002QCUIZC/ref=sr_1_6?ie=UTF8&qid=1350152535&sr=8-6&keywords=ac+adapter+hp+dv2000
The plug end that plugs into the laptop has a Center Hole, and a cylindrical metal outside shell.
The center hole is the Positive connection.
The cylindrical metal shell on the outside is the Negative connection.
Multimeter function knob set to DC Voltage, the Positive (Red) probe lead goes to the Center Hole.
The Negative (Black) probe lead touches the cylindrical metal shell.
[An inexpensive multimeter can be purchased for as little as $5 to $12. Available in a multitude of stores. An auto parts store is but one example, or look on the checkout aisle racks of major discount stores.
If just a symbol, the symbol for DC Voltage is a dotted line over a solid line. More expensive multimeters have an auto detect feature, that sense when the multimeter is connected to AC voltage, or DC voltage )
You should read 18.5 Volts (DC)
While testing have an assistant gently wiggle the cable from AC adapter to laptop, and the power cord to the AC adapter. A fluctuation of the reading indicates there are broken wires.
AC adapter checks out OK?
Go to the DC Power Jack.
The DC Power Jack on the laptop may have DC_IN next to it.
It has a Center Pin, and surrounding metal shell.
Battery REMOVED, use a No.2 pencil, and see with the easer if you can move the center pin.
If so the jack needs to be replaced.
The DC Power Jack for this model series is attached to wires, that end in a small white plug.
The small white plug plugs into the motherboard.
Easier to replace, than models that have the DC Power jack soldered directly, to the motherboard.
It's a DC Power Harness, and HP labels it a Power Connector Cable.
HP 430462-001 for models that have a UMA motherboard.
HP 430461-001 for models using an Intel processor.
DC Power Jack checks out OK?
Power On switch.
http://www.ebay.com/itm/New-OEM-Power-Switch-Button-Board-for-HP-DV2000-DV2500-DV2700-HL50-4F615-001-/300734714047?pt=Laptop_Adapters_Chargers&hash=item46052f90bf
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=1817074&
In the list click on -
HP Pavilion dv2000 Notebook PC Maintenance and Service Guide
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name, it may take up to 30 seconds before the first page comes up.
The PDF reader page numbers, and the actual manual page numbers, do not match. When I refer to a page it is the PDF file page.
Go to Page 141 - Switch Cover
Pages 142 and 144 have more details on the Power Button Board.
(Power Button Board is HP part number 417084-001)
How to test?
Multimeter set to OHM. Straight pins (2) in the socket holes of the removed, Power Button Board's cable connector.
Positive probe lead to one pin, Negative probe lead to the other straight pin.
Press the Power On button.
ANY reading indicates a good Power On switch.
No reading of course means a bad one.
(Remember; the Power On switch is a Momentary Contact Switch.
You will just get a brief reading on the multimeter, if good)
Or you can use a small flat tip Jewelers screwdriver, and TEMPORARILY touch the two contact pins on the motherboard, where the Power Button Board's cable plugs into.
Page 179 for the Display Switch Lid Module,
(HP 417087-001)
http://www.sparepartswarehouse.com/HP,Laptop,Part,417087001.aspx
Unplugging the Display Switch Lid Module from the motherboard, and pressing the Power On button, starts the laptop, you need a new lid module.
Power Button Board, (Power On switch), and Display Switch Lid Module checks OK?
Motherboard problems.
There are Power MOSFETs on the motherboard. These are located close to where the plug of the Power Connector Cable, plugs into the motherboard. (DC Power Harness)
The Power MOSFETs control;
Whether the Battery needs a full charge, or a trickle charge.
Whether the laptop is to just run off of the AC adapter, or Battery.
Look to see if any are blackened, burned, or blistered.
Information using the HP Pavilion dv6000, and Pavilion dv9000 series of Notebook PC's,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Just to show the average cost of a Fairchild Semiconductor - FDS6679 - Power MOSFET,
http://www.mouser.com/Search/Refine.aspx?Keyword=FDS6679
One dollar and one penny USD.
Looking at the second photo down on the Mayohardware blog link, look at AO4407.
(Alpha and Omega Semiconductor)
Look to the right of the Yellow circled AO4407. That small rectangular shaped object, with a dark wide band on it, is a Ceramic Capacitor.
There is one above it of the same size, one above that, and one to the right of the top one.
Average cost of them is around 62 cents to 80 cents.
Average cost of a replacement motherboard is around $40 to $60 on Ebay.
That does it for me right now. Post additional questions in a Comment.
Regards,
joecoolvette
[If you had stated it seemed the laptop came on, but had a blank screen, that is a Different problem ]
Oct 13, 2012 | Compaq Pavilion ZT3280US Notebook
How to synchronize hp pavilion dv2620 battery sir my laptop battery backup is only 10 min so now what to do
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 18, 2010 | HP Pavilion DV2620US Notebook
How do i get my hp pavilion zv5000 to run on ac power only. it will only run on the battery.
Zv5000 Laptops are plagued with problems related to the jack on the back of the computer. After prolonged use the jack tends to make the solder joint loose. Jacks can also go bad. The solution would be to check if the power comes on momentarily when wiggling the plug in the jack, if the power comes on intermittently then chances are you have a loose solder joint and may need repaired by a qualified tech. Fortunately, for the technically savvy this may be done carefully provided the proper static sensitive precautions are taken, due to the fact the computer must be totally dismantled to get to the jack and properly inspect the solder connections and repair or replace the jack. Silver heat sink compound must also replace the silicone on the processor ( one dab and compress, do not spread compound!) The jack need should it be replaced can be found on Ebay
Aug 05, 2010 | HP Pavilion zd7000 zx5000 zv5000 presario...
ZV5120 pavilion notebook powercord not connecting
You can get an exact adapter from eBay link below, they are quite cheap. Sometimes the break is close to the end of the plug, and sometimes, the actual solder on the socket inside the unit is fractured, causing intermittent connections. Often we are able to use the old cord Plug, and graft on the new power Lead. However it is wired and regardless of how many wires are inside, the is only One - Negative, the OUTER contact. The INNER Contact is Always + Positive, sometimes there are three wire inside, TWO are Plus, and ONE, the shield, is negative.
http://shop.ebay.com/i.html?_nkw=HP+Pavilion+zv5000+power+supply+&_cqr=true&_nkwusc=HP+Pavilion+zv5000+power+supplly&_rdc=1
Mar 15, 2010 | HP Pavilion zv5000 Notebook
My HP laptopZV5000 is having charging problem
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Nov 06, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP Pavilion zv5000 - No power with battery in.
the jack is the problem it is not getting enough power to laptop
Nov 02, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
HP ZV 5000 AC PROBLEM
You either have a bad adapter or a broken power jack in the laptop. To check the adapter use a multimeter set to voltage and connect one lead to the center in and the other to the outside metal contact. You should get a reading from 18 to about 26 volts. If you get no reading then the adapter needs to be replaced. If you get the correct reading then the power jack in the laptop will need to be replaced. If yo are ok with electronics repair you can get the jacks from Ebay.com if not your local computer repair shop should be able to do it for you.
I hope this helps, If so please rate my solution,
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair.
Jul 08, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
Computers & Internet Logo
99 people viewed this question
Alun Cox
David Payne
David Payne
