Question about EliteGroup K7S5A Pro Motherboard
How do rewire the motherboard k7s5a
I took the wires out of the motherboard and i forgot how to put back on
  • 1 more comment
  • keonidanahey Dec 22, 2007
    yes im new to this computer stuff im trying to build my grama a new computer so i brought a mother board model number k7s5a but i do noy know how to put all the wires back on the board.
  • islanduso Dec 27, 2007
    Yea i have the same problem. i took out my motherboard and switched the case with a new one. when i turn it on it beeps more than once. Please help. thank you.
  • steliosa Sep 07, 2008
    i remove the motherboard and plaset in a diferent tower box and i dont know where the 3 wires for ( H.D.D led - POWER SW - RESET SW )
    they get conected ....
    any help please?
    Problem Solver:
I also have the same problem but I am confused because i still have wires i don't know where they go...Like TPB-,TBP+,TPA-,TPA+,1+D,2+D,1-D,2-D,
1+5v,2+5v,VP,VG. Please help me with this problem. I done gave myself a headache.
Posted on Jan 25, 2008
    President:
  • 2,351 Answers
Go to this Asus site. Fill in the needed information on the right. This will than take you to your board. Download the manual.
Using the manual you will be able to set up your switches.
On the board and it is very hard to see. Every pin has a plus sign "+", that is the power. Black and some times white is ground. Other colors like red and green are "+".
http://support.asus.com/download/download.aspx?SLanguage=en-us
Posted on Dec 04, 2007
  • Mike Peluso
    Mike Peluso Dec 31, 2007
    Well it seems that Asus no longer shows the K7S5A Mb any longer but I do know how the cases HDD, power, reset & speaker connectors go. A strong fashlight will be needed.
    Use the flashlight and you can see typing on the board for the pins. You will also see color coading at the base of the board where the pins Protrude. Each color is for a connector.
    Asus boards are marked but hard to see. Two rows of pins located at the bottom right hand corner of MB. Starting with the bottom row of pins, the last two pins at right edge of the board. These two are for the RESET switch. The ground, "negative" wires will be colored Black or White. All negetive/ground wires will face to the right of both rows of board pins. All connectores connect left to right & not up & down across the rows. Moving to your left now, skip one pin. Connect the PWRSW known as the Power switch. The case connector is like the reset connector a two pin connector. Skip the next three pins on the board moving left & connect the hard drive led. This completes the bottom row of pins & connectors. Move to the top row board pins, directly above the IDE connector. Connecting again left to right, connect the PLED known as the Power Led. The PLED spans across three pins but you only use the two outer pins off the board. The middle pin is not used.
    First pin "left edge" like the bottom is a Positive to its right skipping 1 pin is its negative. Next skip three pins moving to the right. The last four pins off the board is for a case speaker. Most case speakers connector is a four pin connector but only use the outter two holes. Ground is the last pin on the right edge of board. Long explaination I know but its the best one can do without a picture. All done.
I am working on a friends computer and he has a k7s5a pro Mobo..
Maybe it requires DDR2 or DDR3 RAM. As it is there are only 2 DIMM slots, so check the FSB. If it does not match asper the manual then you might need to replace the RAM with the appropriate one....sodeep
Mar 19, 2009 | EliteGroup K7S5A Pro Motherboard
I Have a Motherboard K7S5A xp 1800 I would like to now if it will hold 2x1gb of ram for a total of 2gb of ram Please Help Thank You
No, Maximum memory on this board is 1GB total. There are four memory expansion slots (places to put memory sticks.)
Mar 14, 2009 | EliteGroup K7S5A Pro Motherboard
Hey Ya'll i have your motherboard K7S5A an i can get it to start up however when it loads it tells me hdd error hdd slave error but im not sure i have the wires for the hdd and power wires in the right...
Either the wires are not properly hooked up but more likely would be that you have the jumpers on the back of the hdd's improperly set. Hope this helps.
Jan 09, 2009 | EliteGroup K7S5A Pro Motherboard
Please Help!!!!!!!!
Hi - You can download the manual from the link underlined in blue below:
761GXK8MC-RS
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 17, 2008 | EliteGroup K7S5A Pro Motherboard
ECS K7S5A intermiteen symptoms
explain the intemittent symptoms more clearly
Mar 02, 2008 | EliteGroup K7S5A Pro Motherboard
Motherboard drivers
None , windows 98 only uses the native drivers.
hopefully you have win98 Se for the usb.
Jan 26, 2008 | EliteGroup K7S5A Pro Motherboard
Rewire the motherboard k7s5a
well really you just have to put the wires to where they fix right. but for some wires, they look the same so you have to find a lable on the side of the wire and try to find the same lable on the motherboard. in some cases there are no lablings so it would be much hard to tell you how. but if thats the case i will do so.
Jan 25, 2008 | EliteGroup K7S5A Pro Motherboard
EliteGroup K7S5A Pro Motherboard Logo
632 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
