Kenmore 35622 Upright Vacuum
Problem for Kenmore 35622 Upright Vacuum
Vacuum is making a loud noise
By SMarie on Dec 03, 2007
My vacuum started making a loud noise and it smells hot. I checked the belt which is fine and there is nothing stuck in it. Help
Comments:
Dec 03, 2007
- Thanks! It's certainly worth a try!
Same Problem
Jan 23, 2008
-   I am having similar problem. I checked the inlet near the brush and it was plugged up with carpet fibers and dirt. I cleaned it out and the noise stopped.....for awhile. The vacuum is making the same loud humming (air suction noise) even though there is nothing plugging up the hose. Thinking of taking it in to Sears.-   edwardsd24
Solution #1
posted on Feb 05, 2008
Not Rated)
reddevil6
Rank: Guru  Kenmore Expert
Rating: 88%, 1797 votes
Is the smell rubber or electrical. If rubber then the belt is slipping and needs to be replaced, they stretch after awhile. Also is the brush roll turning freely, or is it bound up, it may have to be replaced. If the smell is electrical, then probably the motor is going bad and will have to be replaced.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 35622 Upright Vacuum
Questions and Unsolved Problems for Kenmore 35622 Upright Vacuum
Do you recommend Kenmore 35622 Upright Vacuum?
Answer
Answer
tiene virus como puedo quitarlo sin perder mis documentos que tengo guardados en ella
Answer
how do i change the belt on kenmore upright vacuum
Answer
Our Kenmore makes a loud, horrible clogged-sounding noise whenever the house is affixed to the house... (More)
Answer
How to remove roller on Quik Clean Kenmore Upright Vacuum?
Answer
there is no power to my kenmore 116.36622 and have tried different outlets that do work. the... (More)
Describe your Vacuums problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuum Experts
Top Vacuum Repairmen
in Newport, KY
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
