Question about Indesit 24 in. IDL700 Built-In Dishwasher
D1260 indesit dishwasher
Light 1 and 2 flash and the applience stops and will not empty. Have tried cleaning the filter but no good. I read that it may be the pump which requires to be cleaned but( it is integrated ) I dot not know where the pump is or how to clean it.
  • 76 Answers
The pump is situated underneath at the right hand back of the machine, you will need to remove the right hand panel to gain access. its not an easy job as it will probably need replacing. a local engineer should charge around 60-70 gbp
Posted on Dec 04, 2007
SOURCE:
Indesit dishwasher idl40 s I have lights 1 and 3 flashing after shortly staring it's cycle. Then it empties and stops but there is no water hardly when I open the door. Any ideas please??
It would appear that the washer is not getting water, though it could be aborting the cycle early for some reason.
Try to google "Indesit dishwasher idl40s lights 1 & 3 flashing", and various permutations to see what others have said. At the least you need to understand what that pattern of lights flashing means.
There is an electric valve that the washer controls to allow it to fill with water when needed. This may be clogged or may have failed.
Pursue the flashing light issue first so you understand what the washer is complaining about.
Pete
Aug 30, 2015 | Indesit Dishwashers
I have an indesit dishwasher. It starts for 2 mins & then stops and then lights flash. I've had the plumbing checked and that's all fine. If it is the anti-flood where do I find it & how do I fix it
You need to understand what the washer is complaining about. Try to find the error on the web (Google it).
You checked the plumbing, and it is all fine. So who checked the plumbing & why did they not complete the troubleshooting? The plumbing is fine - means there are no Geysers springing from the pipes? How about a clogged inlet valve? How about the internal filter (which it sounds a lot like to me)? Take the internal filter out and clean it by hand.
Google "indesit anti-flood" to start tracking down how to deal with this eventuality.
Good Luck,
Pete
May 26, 2015 | Indesit Dishwashers
Indesit DI 620 which won't drain water
this appliance is a built in dishwasher and may have somthing jamming the pump,this can only be acessed from the bottom and may require the appliance being removed,also check that there is not a blockage at he sink.
Apr 19, 2009 | Indesit 23 in. DV62 IX Built-in Dishwasher
First two lights of four are flashing
when my ones lights flashed (lights 2 and 4) I thought it was def broken, i then discovered it was a knife in the top tray stopping the shower from spinning. worth a try- make sure its empty when you test it.
Feb 14, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit D41 lights 1 & 2 flashing
1, Tilt machine and remove base plate 6 screws.
2, fixed to the inner ring at the bottom of the machine is the water level control.
(brown, round with 3/4 wires attached.
3, remove it, lift and pull forward.
4, remove the attcahed clear plastic tube.
5, tip up and drain out any water in the unit, Should be none.
6, Blow throught the free hanging rubber tube, should be clear
refit.
Dec 21, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL 50 Dishwasher
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
Jun 04, 2008 | Indesit 24 in. DE73 Evolution...
Indesit IDL 530 Dishwasher
Switch off, turn off power, turn off water, disconnect water inlet hose, check for blockages, remove filters, clean filters, refit filters, check water supply, reconnect water supply, reconnect power, turn on - problem solved.
Apr 12, 2008 | Indesit Dishwashers
Indesit dishwasher
machine is flooded in base
means you have a leak in dishwasher
dismantle check feed pipe to top basked probable faulty feed pipe replace if so
Feb 23, 2008 | Dishwashers
Indesit idl 705 Dishwasher
Having read another users fault (LUNNY) that has same fault. They got engr out and it was a blocked pump. Where is the pupmp located on this model as I have the same fault and want to resolve it asap.
Aug 24, 2006 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit 24 in. IDL700 Built-In Dishwasher Logo
166 people viewed this question
Top Indesit Dishwashers Experts
Marvin
Marvin
Paul Bade
NOEL
NOEL
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
