Question about Mitsubishi WD-52525 52" Rear Projection HDTV
TV Shuts down
Mitsubishi WD-52525 comes on and then green lights starts flashing and tv shuts down. If you wait tv will turn on again but problem happens again
  • danh Dec 04, 2007
    the tv has worked all day i have ordered a servce visit but not sure if i should keep it.
  • Anonymous Mar 31, 2014
    Shuts off
  • 4,402 Answers
Convergence amp IC's i would start with.
Posted on Dec 03, 2007
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
We recently changed the bulb cartridge. We receive broadcast tv, no cable, no sat. Our WD-52525 had worked perfectly until we changed the cartridge. Now it will not stay on, it shuts down and the green...
Hi the cartridge's work is to hold the lamp in place it will not go faulty or melt or will prevent tv from lighting up.Did you close the door cover on the back properly.Did you reset the lamp timer? Do it by unplugging tv wait 5 min and plug it back again.Pay attention to clicking sounds or like wanting to turn on it could be a bad ballast and that's the board that powers the lamp.Hopefully you dont have "The green light of death" Issue. It tells all about it here Good luck and God bless you!
Oct 05, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
Jun 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
Mitsubishi wd52525 shows error code 37
error code 37 is either the dmd fan or the lamp fan. you can see the dmd fan with the cover off. you cannot set the lamp fan as it is under the light engine. I guess the easiest thing to do is get a lamp fan 299P282010 and a dmd fan 299P283010 and change them both.
Nov 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Yellow status light on mitsubishi wd-65733 tv
When tv goes out, press the menu and input buttons. The green light will flash with a 2 digit code.
Jul 26, 2008 | Mitsubishi WD-65733 65" HDTV
Mitsubishi WD-62628 power shuts off!
hold the MENU and DEVICE buttons when turning on the TV and get error code
Dec 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd 52525 dlp shuts down
mitsubish has issued a service bullietin about the problem. which means ussally they will pay for its repair. the reson it says airflow bock is that there is a temperture sensor that is at fault... it needs replaced.
Dec 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
138 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
