Question about HP LaserJet 4350TN Printer
HP Laser Jet 4350tn issue
I have a LaserJet 4350tn where I work. The printer does not give an error until a print job is sent. The print job does not print and control panel on the printer will either say "tray 2 waiting to lift" or "tray 3 waiting to lift." I have tried several things from the HP website to no avail. Any help would be appreciated.
Take the paper out of the trays and check the trays mechanism, lift the tray by hand and make sure nothing is obstructing the movement or something broken.
Posted on Dec 21, 2007
    President:
  • 4,402 Answers
Open tray 2 and tray 3 and try it.
Posted on Dec 03, 2007
HP COLOR LASER JET 2605 PRINTER 49 ERROR MSG DISPLAY SOLUTION
49 errors are most commonly caused when the printer receives a print job with commands it does not recognize. You can try updating the firmware as this will often resolve the error. Go to HP's website to find the most recent firmware, however this model is fairly old and likely the firmware update will be fairly old.
Sep 25, 2014 | HP Laserjet 2605dn Workgroup Laser Printer
49.4 C18 laserjet 4345
49.XXXX is a fatal catch-all error. Could be firmware problem, network, print job. If the error occurs when you try to print, clear the print queue. If the error occurs when the printer is just sitting idle, reseat the formatter. Try powering on without the network cable attached. If it still happens replace the formatter. Could be a corrupt print job being sent to printer. Print something else.
Mar 28, 2014 | HP LaserJet 4345mfp Printer
Error 49.33.03
First turn off the printer and then delete the job held at the computer in the print queue. Then turn the printer back on. The error should go away. Try printing the document again to see if the error returns. Normally a corrupt print job causes this issue. If the error appears with no jobs being sent to the printer then the formatter board is most likely bad.
Mar 10, 2014 | HP Color Laserjet Enterprise Cp5525n...
HP LASER JET 2300 52.00 ERROR
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
4. Replace the engine board.
Tallon41
Sep 12, 2012 | HP LaserJet 2300 Printer
Hi Sir / Madam I am getting the error while printing . The error is Ecomode disabled.
It might be economy mode, go to menu >configure device >print quality> economy mode> make it on..
Sep 10, 2011 | HP LaserJet 4350TN Printer
My HP Laserjet 3050 used to print automatically after each fax sent a call report showing that the page(s) had sent. For some reason, after a service call, now it doesn't do that any more and I have...
Hi Dear
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jun 01, 2011 | HP LaserJet 3050 All-In-One Printer
I am getting Error 49..turn off and turn on error again and again from HP 2605 Color laser jet printer. Plz help.
It's a firmware error.
Do ALL your print jobs give this error. If it is just one job that causes the error, something is corrupted with the software.
If every print job causes the error, it's the printer. Try printing after removing DIMMs from the printer. If you can try plugging the printer into another port on the computer or router.
When all else fails, go to www.hp.com/#support and download the latest firmware and install it.
By all means READ the directions first.
Jan 31, 2011 | HP LaserJet 2605dn Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
HP LaserJet 4350TN Printer Logo
640 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
