Question about Fine Digital FineDrive 350 GPS Receiver
FineDrive 350 GPS
Unit works great as long as you are attached to one of the power sources, however the battery loses charge in 3 minutes. It appears to be ruined by over charging. I like the unit. It meets my need, but I need to have the battery function restored. Question: How/Where do I go to get the battery replaced?
  • Anonymous Dec 29, 2007
    New Information: The Fine Drive 350 was made for Fine Tech by the Nav Tour Folks. They have an outgoing unit called the Nav Tour 147 which is identical to the Fine Drive 350. I have emailed their support unit and asked about getting a new battery or better yet, will they service the unit? I will keep this item posted on the result.
    Scholar:
  • 107 Answers
Finedigitalusa.com had a repair service but I have not been able to contact them for some time now. sorry...
Posted on Dec 28, 2007
  • vince954 Dec 28, 2007
    I took a peek inside mine, it uses a 3.7v 1400mah battery like those used in cell phones but with a 4 wire connector. I cant imagine being able to locate this aside from the factory. the company that finedrive sends you to for service (C&C) wireless did not show anything for the 350 on their site but they do offer repairs on the 400. it may be worth the call.
    I do have one problem you may be able to help me with, in my unit the memory card poped out and my puppy found it, well, to make a long story short he did not like the taste. I now find myself in need of the data on the card, would it be possible to send a blank card to you or any other member that could copy the data to it for me?
SOURCE:
My device will not come on
Things to check:
1. Make sure that your car receptacle has +12VDC. Try another device to confirm.
2. Make sure that the car charger is working properly. Most have a fuse in the tip. It could be blown. It may not be converting +12VDC to +5VDC which is required to power the GPS. Try another charger with the GPS.
3. Common problem with the 25xx series are loose/broken USB charger ports. This will prevent the unit from powering up with an external power source and will prevent the battery from being charged. Eventually the battery will lose its charge and since the USB charging port is loose, the battery will not charge and the unit will appear dead. More info here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Apr 03, 2016 | Garmin nuvi 2597LMT 5" GPS Navigator -...
Purchase battery charger for model 350
How old is unit? these have not been made for several years and locating any replacement parts will be difficult. the Finedrive units were produced by the same company as the Navman units, but they no longer support them except for batteries.
May 12, 2011 | Fine Digital FineDrive 350 GPS Receiver
Its any softwere update for this fine drive 350 , or any link I can download driver , I dont have the oryginal sd card Thanks Mike
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
Jan 21, 2011 | Fine Digital FineDrive 350 GPS Receiver
My error message says "A GPS-signal is not available now...."
Try hinging the antenna out from the back and angling it so the words FineDrive point up at the sky. It often takes 5 or more minutes to find the satellite, but it always finds it.
Feb 14, 2009 | Fine Digital FineDrive 350 GPS Receiver
GPS-Finedrive 400
try holding the bottm right buttion on boot, should go to windows ce, if not you may be out of luck...
Aug 24, 2008 | Fine Digital FineDrive 400 GPS Receiver
Charging
hi,
did you know it charges through usb of computer you'll see the red lite on the unit cool and give it 4 hours
Jun 07, 2008 | Fine Digital FineDrive 350 GPS Receiver
Garmin 350
easy solution...you need to keep this plug above attach to the the Garmin 350...when charging in the car or at home ...plug the power source to the back8dac8e5.jpg. Hope this will help...i had the same problem.
Feb 21, 2008 | Garmin nuvi 350 GPS Receiver
Reset
both cases could be due to a dead memory battery. these have a very tiny button battery in them to keep some memory such as GPS position. if it dies then the GPS may take longer to get a fix and data such as your last position is gone each time you boot.
Jan 17, 2008 | Fine Digital FineDrive 400 GPS Receiver
Finedrive 350 sd card damaged.
I have a cd with the programming, including the maps. If you send me a blank with a SASE, I will copy the disk and send it back to you. Or, if you'd rather, send the data card and I can reload it and return it to you. I have learned from FineDrive that no further updates of the 2005 maps on the cd are expected to be forthcoming. NavTour has not answered me yet. They may be able to fix any battery or card problems.
Dec 30, 2007 | Fine Digital FineDrive 350 GPS Receiver
Losing GPS signals.
i also have the same problem my gps loses the signal i left the unit on power for two days and still no signal please help.
Nov 26, 2007 | Fine Digital FineDrive 400 GPS Receiver
Fine Digital FineDrive 350 GPS Receiver Logo
65 people viewed this question
Top Fine Digital GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Fine Digital GPS Expert? Answer questions, earn points and help others
