Question about Linksys Wireless-G WRT54G Router
Linksys Router Range
What is the range of the linksys router in a typical home or the square footage can one router cover?
  • 26 Answers
I have two wireless b routers in my home. Its not really a question of the square footage but what obstacles are in the way. My son purchased a Wii and the router would not reach it reliably. I thought about the path the signal had to go from point a to point b and it was directly through a furnace, a fuse panel and a bathroom mirror so I thought that was not fair even though it was only a few rooms away on the same floor. I purchased a wireless access point (router number 2) and put that up higher in a room closer that was easy to run a wire to and plug in. This gave me the upper hand by missing the two large metal objects. I am still having more trouble getting this signal to reliably work than I do beaming my signal across about 800 feet of open field to my mother in laws house where she has a good signal with a wireless card. We learned to put the computer right on a table in the window so I can actually see line of site from my loft office to her 1st floor office and it works. I was about to try all those kinds of antenna's that you might have become interested in.
My advice, don't mix brands I made the system all Linksys and this helped more, get the router up high in the house rather than on some table or the floor, think about the obstacles and you will make progress like I did.
I don't have G but B but I think this will help. Oh yeah, for about $10 I purchased the longer antenna's from Radio Shack that are a steal. This also was part of the recipe for success. I have no cobbled up antennas, but honestly my signal is weak two floor down from the loft in the basement. If I was starting over it would be a router in the middle of the house in the basement perhaps up high and in the middle of the second floor up high with a nice shelf and an outlet so I could get to it easy and see if from a distance without a ladder. Real life: find some shelf you already have, run an extension cord, buy a long network wire already terminated and put the router up there to try it out before you install it for good. I've could go on with lessons but this is a start.
Posted on Dec 03, 2007
SOURCE:
How many feet could it connect
It depends. Eye of site it could connect 50 to 150 at the max
Mar 26, 2011 | Cisco Linksys Wirelessn Router Black...
What range expander should I use with a Linksys Dual Band Wireless-N Router Model WRT 320N?
For this router you can use the Linksys range expander model WRE54G v3 take not of the version number that is important since the older range expander don;t work on all routers.
Feb 13, 2011 | Linksys WRT320N Wireless Kit
Signal is not strong enough to connect laptop downstairs away from Linksys 2.4 ghz wireless router in my home network. I have ethernet downstairs, can I attach another wireless router, as well as my PC to...
Looking at the specs for that Linksys router, it is a "G" size router. Most "G" routers only have an average indoor range of 150 ft. and that also depends on what type of construction materials are in the home that could hinder that range and the signal. Another router attached would only degrade the signal even more, that is not recommended. A stronger ranged router would probably be a better solution, possibly an "N" or "N+". Hope that helps.
Jan 22, 2011 | Computers & Internet
Cant find a strong enough connection
You need to buy a Linksys Wireless-G Range Expander to boost the signal
  • Move your wireless router to a central location in your network, keeping in mind that the router should be at waist level at the very least, not on the ground.
  • Plug in the Linksys Wireless-G Range Expander in the room where your wireless router is. You'll move the range expander later, but for setup purposes, it should be in the same location as your wireless router.
  • Press the Linksys Wireless-G Range Expander's "Auto Configuration" button for five seconds, which will allow the range expander to detect your wireless network and configure itself with the appropriate settings.
  • Unplug the Linksys Wireless-G Range Expander and relocate it to a location closer to the Xbox 360.
  • Ensure that the antenna for the Linksys Wireless-G Range Expander is pointing upward, and keep in mind that the higher the range expander is placed, the better performance you will get out of it.
  • Plug the Linksys Wireless-G Range Expander back in, and your wireless network should have a much greater range, ensuring that your Xbox 360 is able to maintain a good connection to the network.
  • Dec 29, 2010 | Microsoft Wireless Network Adapter Xbox...
    Can't get on line with my Linksys wireless router
    you can daisy chain ..but you will need an eithernet run from the fios router to the linksys...
    Jun 25, 2010 | Linksys Wireless-G WRT54G Router
    Wife range
    Get a Range Expander in between
    Mar 24, 2010 | Linksys Wireless-G WRT54G Router
    Linksys Wireless-G not connecting to internet
    Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
    Here's why you are getting the "low connectivity" message:
    Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
    The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
    Cheers!
    Apr 19, 2009 | Linksys Wireless-G Broadband Router
    I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
    Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
    You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
    10.150.1.1 should work.
    Oct 08, 2008 | Computers & Internet
    Linksys wireless G range expander
    Hi David,
    I need to know that what type of router u r using.
    If it is Linksys router just follow these steps,
    with the help of the Ethernet cable connect the range expander to any one of the 4 ports in the router...
    ur computer shuld be directly hook up to the router..
    open internet explorer in ur computer..in the address bar type in 192.168.1.240(ip address of the range expander)
    it will prompt for a username and password...leave the user name blank and the password will be admin.
    u can see the linksys range expander set up page...
    u can find SSID at the bottom of the page...
    ur router's SSID and the range expander's SSID should be same..and also the password should be same..
    If the ssid or password mismatch between the router and range expander u can find these kind of Error messages...
    Good Luck....try it and revert back
    Jul 03, 2008 | Linksys Wireless-G Broadband Router
    Security
    If you do not have wireless security enabled then anyone within the range of the radio transmitter will be able to use your internet access.
    A G band router has about a maximum range of 300 feet which is greatly reduced by walls, wiring and other items in your home.
    If your using a wireless laptop you can do a site survey by walking around outside your home to get an idea of the range your router has.
    Dec 28, 2007 | Linksys Wireless-G WRT54G Router
    Linksys Wireless-G WRT54G Router Logo
    132 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    mark
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
