Question about O2 Xda Atom
MN1 bootloader when i inserted my sim then the battery were put back then 5 seconds after that there is mn1 bootloader appears and then some files are not detected and then it freezes right there....
    Problem Solver:
  • 8 Answers
First try turning on your phone without the memory card. I suspect you have an SD flash upgrade files in the SD card that's forcing the phone to reflash every time it turn on.
If it is still failed, you could try doing a hard reset? But be carefull, you'll need to back up all your data first, cause it will delete all files and data in the phone.
Posted on Feb 04, 2008
My print jobs say printing but no result. stays in the que. printer window shows mn1 and sleep, other than the date and time
If you know how, open the 'printers folder' in your computer and delete all the printing jobs.
Switch off the printer and unplug it from the computer.
Switch off the computer.
Switch on the computer.
Connect the printer and switch it on.
Hopefully it will have cleared itself
Mar 12, 2016 | Brother MFC Office Equipment & Supplies
My fax 2820 has mn1 in the corner of the function window where it should read fax, and is not functioning right what does this mean
hit "menu/set", "0", then "1". using arrows to select "fax only", hit "menu/set", then "stop/exit".
razors
Dec 02, 2011 | Brother IntelliFax-2820 Laser Fax
On the display it has a Mn1 listed. Since this has appeared our machine won't accept any faxes. What do I need to do to clear this and have it receive faxes?
try this. press "menu/set", "0", and "1". use your arrow buttons to select "fax only", then press "menu/set" and press "stop/exit". you should now be able to receive faxes automatically.
hth,
razors
Jan 11, 2011 | Brother IntelliFax-2820 Laser Fax
I changed over to other nam and powerd down phone
PLEASE BACK UP YOUR FILES BEFORE UNLOCKING
This will also bring the phone to default settings
1. First do a CUSTOM reset: *2767*2878#
turn off the phone
2. take out the battery and sim and put wrong network SIM and insert only a half of it,
Very important so it won't ask for network password and shows "Insert SIM" message.(possibly in a different language)
Now put the battery ,and switch the phone on .(phone shows "Insert SIM" message.)
3.push the sim fully in at this stage the phone is still asking to "Insert SIM"
4. Make a FULL reset: *2767*3855#
5. The phone should reboot working with "wrong" sim inside.
6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#
7. Now Disable network lock By typing: #7465625*638*00000000#
Phone is unlocked
Mar 06, 2010 | Cell Phones
Network key samsung e250
unlock it by following...
1. First do a CUSTOM reset: *2767*2878# (star 2767 star 2878 hash)
turn off the phone
2. take out the battery and sim and put wrong network SIM and insert a half of it,
3.With out turn off the phone push the sim fully in. At this stage the phone is still asking to "Insert SIM"
4. Make a FULL reset by typing: *2767*3855#(star 2767 star 3855 hash)
(star 7465625 star 638 star 8zeros star 8zeros hash)
(hash 7465625 star 638 star 8zeros hash)
Phone is unlocked (check with *#7465625#)
Sep 02, 2009 | O2 Samsung SGH-E250 Cellular Phone
LCD display has wrong date
I finally found what I wanted on the Menu and it worked!
P.S. I'm 83 and not all that swift.
Jan 10, 2009 | Brother MFC 420CN All-In-One InkJet...
Unable to boot up my O2 Xda Atom
Dear cafei,
Go to boot loader on your O2 XDA atom by removing batt+pressing camera button+plugging in the batt back WHILE still press holding the cam button the ue the stylus to press soft reset button, then connect to your pc via usb, then run the update program (most refer to it as DSUU, u can download one from seeo2.com) just wait for the progress to complete and you're done.
if in case you get stuck at 6%, unplug usb cable, remove battery, then insert battery while press holding the power button, while still holding the power button, press the reset button with the stylus, it should show the o2 splash, wait for any progress. then re-run the DSUU again to perform full flash.
disclaimer:
please take note that i did not suggest any 3-party rom, it is best if you try the O2-released ROM (or DSUU).
Jun 02, 2008 | O2 Xda Atom Exec Smartphone
My o2 celphone won't turn on
O2 XDA Atom / O2 XDA Atom Pure / HP rw6828:
To perform a hard reset, use the stylus while pressing into the reset hole, press the power on/off button at the same time. Screen will prompt you to press the Green call and Red end call button together to confirm on hard resetting the device.
*Note: Hard resetting the device will cause the device to be reset back to its original factory default settings and all data will be lost.
i hope it will help your prob.
Dec 01, 2007 | O2 XDA Mini S Smartphone
Printer keeps turning off,,,error message MN1 in lcd
I realise this is an old question but I recently had a similar issue with our MFC-5860CN not receiving faxes and displaying the "Mn1" code. As it turns out "Mn1" means the machine is set to manual receive and was therefore not automatically receiving faxes. You will need to locate the "Receive Mode" option in the menu and change it to "Fax Only" or "Fax / Tel". Unfortunately I dont know what could have caused the turning off and on that the OP mentioned. I'm a little late to the party but I hope this info can help someone else!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Computers & Internet Logo
276 people viewed this question
Top O2 Computers & Internet Experts
zurysk8
Level 1 Expert
xxxxxx xxx
Jax Planet
Jax Planet
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
