Question about Baumatic Upright Freezer BV12A
Freezer not cooling
I have a built in Baumatic freezer, it's been working fine for about 9 months but it has now stopped cooling. i've turned up the thermostat, switched it off and on and nothing has worked - how would i check if the seal is ok and could this be another problem?
  • 833 Answers
ZoeM, I am thinking freeze up from humid conditions, too much 'window shopping' or bad door gasket (is that the seal of which you speak?). If the unit is only 9 months old...it has a full warranty. Don't do anything to it beyond what is described here.
Defrost the unit completely. If you can get warm air to the coils, do so. If not, leave it off and open for 2 days to completely defrost.
To check most door gaskets: first, make sure the gasket and its mating surface are both clean and visually undamaged. Next, test by simply closing the door on a piece of paper...use a strip about 2-3 inches wide and long enough to go inside the unit that you can slide across the gasket/frame surface. Close the door with the strip near any suspect areas. You should not be able to pull the strip out easily. Replace any damaged gaskets.
Posted on Dec 04, 2007
SOURCE:
F1471 vi Miele freezer showing fault code 01 21 _F
From a previous post for a different Miele freezer: "I emailed Miele and this is what they reply: Thank you for your interest in Miele products. That message is a ice fault. If the ice has stopped production, please turn the toggle switch off under the electronic touch panel. To find this please reference the owners manual on pages 7 and 9. I have included the owners manual in case yours is missing. If your machine still produces ice fine just shake the cubes around making sure none are built up along the back wall of the ice drawer. If this continues please contact our service department. Please reference incident number 2698767 should you need to call in. For more detailed information, please visit our web site at www.miele.com or to speak with one of our representative call 800-999-1360." Haven't tried yet, but will post again if it didn't work, otherwise should be the answer"
Nov 17, 2013 | Miele Freezers
Freezer does not freeze anymore
the freezer usually has the condensor coil sandwiched ilong the outer cabnet and in the back the lines come out in to the compressor compartment as a tech i have found the steel line rusts where the epoxy coating is no longer in tact so i would say you most likely have leaked out the refrigerant
Feb 10, 2013 | Freezers
My kenmore freezer stopped working for about two days it had been leaking water for a few months, then it started working again?
It could be that your defrost system is faulty. If the freezer does not defrost now and then it will fill up the cooling fins with ice and get warm. The leaking could also be an indication of two much ice. Did you unplug it when it stopped working and then plug it back in?
Sep 21, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Fridge works freezer does not Zannussi
the fridge will soon stop to! all cooling goe to the freezer first! look to see if there is frost in back of the freezer if not it might be low on charge
Apr 11, 2010 | Freezers
Samsung cool n cool freezer & refrigerator does not cool
samsung refrigerator won't cool how do we fix it?
Apr 14, 2009 | Freezers
Slow icecube maker
the harvest mode is started when the ice cube reaches around 14 degrees so lower the temp in the freezer or decrease the size of the cubes also make sure the fan vents in the freezer is unblocked. check the temp in the freezer should be around 0 degrees.
Dec 12, 2008 | Frigidaire Freezer Refrigeration White...
Rangehood malfunction
My Baumatic Rangehood model BAISL92.2 had the letter A flashing. I was advised by a repairman that it indicated the filters needed to be cleaned with warm soapy water. Apparently in my particular model there is a built in 30 hour timer for when the filters need to be cleaned. To remove the flashing letter A, I was advised to clean the filters, turn off the rangehood and while it was off, press the (-) (minus) button and hold for 5 seconds. It beeped and the flashing letter A was removed. This worked for my particular model - I couldn't guarantee it would be the solution for your model. I hope this is some help.
Jul 22, 2008 | Baumatic Upright Freezer BV12A
Compressor Stopping
compressor is running overloaded possible problems bad relay/overload /capacitor dirty or clogged condensers if the unit uses a condenser fan suspect a bad fan. and defective thermostats are notorious for short cycling. id check the coils first and if dirty clean up maybe that can be the major problem.
Apr 22, 2008 | Frigidaire 9 cu. ft. / 255 liter Chest...
Baumatic Upright Freezer BV12A Logo
237 people viewed this question
Top Baumatic Freezers Experts
Dennis Boxerman
AJMAL KHAN
Marvin
Marvin
Are you a Baumatic Freezer Expert? Answer questions, earn points and help others
