Printer Stopped Working
My HP 7300 printer just stopped working after changing from one location to another. There is no power getting to the machine. After plugginng it in it remains powerless - no panel lights or indication that there is any power tot he machine. I checked the power outlet and that is not the problem. I think it is either the power supply cord, or some sort of fuse. What do you recommend?
  • 1 more comment
  • mountcass Dec 20, 2007
    No power even whne changing to a diiferent power cord and source
  • Anonymous Mar 10, 2008
    While changing out the black cartridge, when reinstalling a new one the power
    light went off, and in the computer it shown it was offline. Ck'd plug in on both ends but still can't get the power to come back on, even by pushing the power on button on the printer.
  • Anonymous Aug 08, 2008
    HP 6300 all in one series same problem...
    Novelist:
  • 208 Answers
The power supply board slides out of the back with two thumb screws. You can pull it out easily and look for burnt components.
Not so sound redundant but the power switch on the right hand side behind the panel is in the on position correct?
Have had a couple of customers not know its there.
Posted on Dec 20, 2007
  • 1 more comment
  • Rick Kasper Dec 20, 2007
    It is rare for that power supply to fail. Actually in 5 years of seeing that product I have not witnessed one bad.
    Here is the part number for what you would need
    119649580
    You can call 1-800-835-6100 and find out the price.
    But I will warn you up front, Sit down when they tell you.
    You can probably replace the printer for the price of the electronich module.
    My curiosity got the best of me. I checked and that item is $499.
    Thought I would save you the heart attack
    President:
  • 4,402 Answers
Make sure it is fully inserted in to the printer, try another outlet also.
Posted on Dec 03, 2007
The printer has stopped working, I tried plugging into a different socket, changed fuse on plug, still not working
have you tested the power supply? (small black box attached to cable , sometimes clips into printer )
try changing it out
Feb 20, 2015 | HP Officejet Pro 8600
Why has PIXMA MX410 printer stopped working? Re-installed Canon PIXMA MX410 All-In-One Printer on hp pavilion 23 widow 8 x 64, system would only print but menu solutions would not. Then printer stoppe
Driver issue. Uninstall and reinstall driver for win 8 64 bit - should work if same worked before. Did you try a system restore to time when printer was working properly?
Sep 11, 2017 | Canon Office Equipment & Supplies
Hp p1005 stopped working
Printer switching on?.Might be power supply failed, replace Power supply board.if you are tech guy..Open left,right & back doors. Check input fuse.. if fuse open replace with same rated fuse, give power, check.. if again fuse is open replace power supply board. if its OK wait few minutes & confirm.. fix it back..
Nov 28, 2011 | HP LASERJET P1005 Printer
I changed my router password and c7200 printer will not work now
If you changed the wirelss password and that has stopped the wireles printer from wrking, all you need to do is to get inside the printer configuration and change the password there as well
If you meant that you changed the router login password and that has stopped the printer from working, then you are mistaken.
Aug 10, 2011 | HP Photosmart C7250 All-In-One Thermal...
Unable to scan or fax. I have a HP Officejet 6110 all-in-one printer, copyer, scanner and fax machine. I have never used the scanner and the fax simply stopped working after years of service. The printer...
Thanx for contacting in fixya....
u need to uninstall the printer software and then reinstall if this problem persists again format ur system c driver it is the only sure solution
regards
john symester
Nov 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hpqscnvw has stopped working in vista network printer HP c7280
Check out this link: I hope it helps you. This solution has had great success so far.
HPqscnvw has Stopped Working
Nov 11, 2008 | HP OfficeJet 7410 All-In-One InkJet...
It started, then stopped!
Seem to be a power problem. Leave your printer unplugged a while. Connect it again and see if the power comes up. Check the power strip outlet, change it for a different one or connect the printer to another outlet on the wall. If still not working your printer needs to be serviced or replaced
Oct 08, 2008 | HP PSC 1210 All-In-One InkJet Printer
Printer stopped working
My HP PSc 2355 all-in-one will not respond to the PC. No problems at all in the past. Help
Jan 16, 2008 | Samsung CLP-300N Laser Printer
90 people viewed this question
k24674
Marvin
Marvin
