Question about PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478 Motherboard
Via p4m800 CE - 8237
This board can't read sata hard disk 160 GB
and i make to it BIOS upgrade to 2007 version and make all changes
in bios to read sata hard disk and there is no any result
  • amy123456 Dec 05, 2007
    i make all changes in bios as u told but my HDD has no jumpers and on its used notes tell don't need any jumper but i will try thing u tell which is 160gig HDD's are only 1.5gig max read/write
    thank u
    thank u
    President:
  • 2,351 Answers
You set your BIOS to "SATA = Enabled" under that set it to
" IDE ". Most 160gig HDD's are only 1.5gig max read/write. Hope you left the jumoer pin on.
Posted on Dec 04, 2007
Update Phoenix AwardBios v6.00
Posted on Apr 10, 2009
SOURCE:
My bio-star p4m800-m7 mother board won't detect my 1terabyte sata hard disk, currently i'm using 160gb ide hard disk....i need to have additional storage...but the system cant detect sata...need...
Hello,Please check the BIOS to see if the SATA ports are enabled. Older boards will disable the sata ports in the BIOS by default. To enter the BIOS, hit the DEl key as soon as you boot the PC.
If ports are enabled, then you probably have to format the drive.Heres how:1. Right-click My Computer and select Manage.
2. Under Storage, click Disk Management on the left pane.
STEP 3 - Format the device / drive / MP3 player
1. Right-click on the 1 TB drive you want to format then select Format.Windows will not recognize the drives file system and will mount it with a drive letter. ex; E:
Sep 09, 2011 | EliteGroup P4M800-M7 Motherboard
Sir, i have an msi n1996 (vt8237r & km400 8237) mother board. My sata 160 gb hdd is not getting recognized in bios. Pl. help. (it is reported somewhare on the net that i have to enter into the...
I enabled SATA support on my BioStar M7VIZ-SATA MOBO (it is km400 and 8237r, like yours) by first installing the VIA SATA RAID drivers. At this point, Windows recognized the device controller but not the 120GB drive. The problem was that the system doesn't support "newer" SATA drives, so I installed a jumper on the disk drive to set it to "150" mode... SATA version 1 compatibility. After that, Windows immediately recognized the drive and mounted the filesystem.
I think it was a Western Digital drive. Other manufacturers have a different name for the same jumper. Also, I read that one type (Samsung?) can only be set to the old SATA standard by getting the drive running in a SATA 2 environment, then using a utility program to adjust the drive's microcode setting.
Good Luck to you.
May 28, 2011 | MSI : MS-7061-020 VIAKM400/A&V&L/SATA...
I have a new 320Gb hard drive, but it is not being recognized by my via p4pb 400 motherboard. Is this a bios upgrade issue?
At most of the cases like yours the problem is not at bios upgrade but at bios settings. If your hard disk is SATA you have to enable the SATA controller and make the necessary setting at the bios. Is your hard disk SATA or IDE? Post me back to provide you more details.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Nov 07, 2010 | VIA P4PB 400 (P4PB 400-FL) Motherboard
Switching from 40GB IDE HDD to 500GB SATA HDD. SATA won't boot.
Hi there
No there is no need to change any jumpers on a sata drive, go into the bios settings and tell the bios to boot from the western digital drive only.
Good luck and thanks for using Fixya!!!!
Feb 09, 2009 | VIA MSI: MSI PT8 NEO-LSR P4 PT800 DDR400...
SATA drive not detected in BIOS and windows does not boot up
i have same problem with WD 250GB sata HDD. with same bord K8V-MX,  i all reday update BIOS with 0502 version.
plz plz plz help me.
CC me [email protected]
Feb 21, 2008 | ASUS K8V-MX Motherboard
Motherboard does not recognise new SATA hard drive
Is your board an ABIT? If so then here is the link to select your motherboard and download the latest BIOS. Make sure to read the web sites instructions on how to update your BIOS. Let me know if you still have issues.
http://www2.abit.com.tw/page/en/download/download_bios.php?pMAIN_TYPE=Motherboard&pSUB_TYPE=Socket%20754
Dec 30, 2007 | Abit KV8 Pro Motherboard
Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
Dec 17, 2007 | Biostar P4M800-M7A Motherboard
Computers & Internet Logo
1,219 people viewed this question
Top PC Chips Computers & Internet Experts
Thomas F. Schneider
Ekse
Alun Cox
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
