Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Water not very hot
I keep my high temp wash and rince activeacted at all times but still wash water does not seem hot enough.also grit which seems to be un rinced detergent is on all the dishs and glasses.I think this is caused by the water not being hot enough.I have turned my hot water heater up and no difference in dish;s. is there a preheater in the unit that may have to be changed out if so were is it located and how to do this would be nice . if not any ideas .......thank you
  • 76 Answers
Yes there is a heater in the dishwasher, but I am suprised it goes through the cycle if it is not heating. for this reason I would suspect that it is a thermostat problem. these are situated underneath the machine. you will need a test meter, to have an engineer do this repair it should cost no more than 70 pound.
Posted on Dec 04, 2007
Admiral washing machine water not hot enough during all cycles.
newer washers have a temp sensor and the washer is programed for around a 100 to 110 degrees F, depending on manufacturer, so if your washer is new it is doing what it is supposed to do, sorry.
Jan 03, 2012 | Washing Machines
Bosch Diswasher
Remove the drain hose and check if you have any residual into it. After 11 years your appliance may need a thourought cleaning.
Check also if the pump has enough pressure.
Apr 22, 2008 | Dishwashers
Dishwasher deposits grit on inside of glasses on top rack
Hi, it sounds like your either using to much soap or the water is not hot enough. Use alittle less soap the next time and see if you have the same problem. Check the water temp after you machine fills for the wash the temp should be 120 or higher.
Clean out the filter and the back flush arm. Also clean the wash arms (every little hole.)
Jun 26, 2011 | Dishwashers
Top Load Roper Washer 7 cycle 2 speed W10330949A Bought 2 months ago ..not hooked up right away either While machine is in the washing cycle...water keeps draining out and refilling. Also Water is...
The drain hose needs to be higher than the top of the water level and yes, there needs to be an air gap so the drain does not siphon. As far as temperature, the machine will automatically put in cold or hot water depending on the temps selected. You cannot get straight hot water from this machine...that is by design. You will have to live with the temps you are given...I know, it sucks!
Mar 21, 2011 | Washing Machines
Washer will not fill up with hot water however it will with warm
Is your water temp on your water heater set high enough? If it is sounds like you are getting water from both hot & cold water valves. If temp is set correctly on machine temp switch may be bad on warm all time.
Mar 12, 2010 | Kenmore Washing Machines
I have a Bosch washer wfc5301uc it is showing error code E02
Could be a faulty inlet valve, or not enough pressure to operate valve,
Remove hose onto valve, and check the water is getting to it o/k,turning off the water to the valve before you undo the hose.
Hope this helps.
Jan 10, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Kitchenaid dishwasher does not run; start/resume light keeps on flashing.
you will probably se the light flashes 7 times then pause and then repeats.this indicates that your unit did not heat the water correctly.
most likely youi dont have enough hot water going into the unit, 120degrees or more, or the latch is not engaging fully. check the temps and then the latch strike. its on the tank and is chrome type metal bracket.
it should be bent down towards the door frame until it just clears the door. if its too high it wont make the door switches work properly and then no heating of the water.
try it.
to get rid of the flashing, push the high temp wash, air dry, high temp wash, air dry. then it will go thru a test cycle and back to normal.
takes about 7-10 minutes.
Dec 31, 2009 | KitchenAid Dishwashers
Whirlpool washing machine...only uses hot water
Make sure the hoses are connected correctly to the water valve on the machine. The connections will be marked with an "H" and a "C".
Given they are correct, most current washing machines have and auto temp feature on the water fill. It allows even cold water settings to bring in some hot water to make sure the water temp is hot enough to efficiently disolve your laundry detergant. The preset temps are usually around 75* for cold, and 105* for warm. Hot water comes in at whatever temp your household water temp is.
Sep 12, 2009 | Washing Machines
Temp stuck on hot on my front loader washing machone
Water temperature is controlled by a switch which activates or deactivates the hot and cold water solenoids. Replace this switch, it is not expensive.
Apr 22, 2009 | Washing Machines
Dishwasher temp.
you probably have guessed right all you have to do is test the voltage to match the original specs.
Nov 20, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
129 people viewed this question
Top Frigidaire Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
