I'm going to assume that the "lights" are images on the screen that seem to have a multi colored shadow. Within the menu there's a choice for convergence, when selected this gives a white cross centered in the screen. Using the arrow keys on the remote (left-right for vertical movement and up/down for horizontal) you will adjust the color that is "shadowing" or get all the colors aligned so the white cross has no trailing red or blue either horizontally or vertically. If you can't get it to adjust or there is no effect then repair is probably the only option.
SOURCE: Sony KP-61HS10 61 in. Rear Projection Television
Mine blinks like 5 or 6 times - picture goes out, but sound stays. It has been at the repair shop for 1.5 months and the tech finally sees the problem. He says 3 new tubes will fix it, but the blue is discontinued. Can anyone confirm?
SOURCE: Sony KP-61HS10 61 in. Rear Projection.
Put tv in standby then press above said buttons. You will be in service mode.
Be Care Full while in Service Mode data handling.
SOURCE: I have a Sony KP-61HS10 that will not turn on.....
hello read my comment on shadie333 i just posted the problem i had, my tv is a kdp65ws550 which is also the same as the kdp57ws550 and kdp51ws550 mine was doing the same thing... ours is fixed... please read it
SOURCE: sony kp-61hs10 tv, has sound but picture goes black after 3 min.
I just had the same problem. If your lucky it might be a free 5 minute fix. The five light flashes mean impropper current. I took the front grill off, then behind that is another black cover, I took that off and noticed the circuit boards COVERED in dust. I then took an air can duster and blew off all the dust... works like new. No more flashes and in an out picture. The collection of dust was interfereing with the electrical current.
Ben
Five blinks is a video abnormality detection and I am all too familiar with this repair... One or more of the crt's in this unit has a bad set or failing guns in it... You can have a local tech bring out a crt tester and rejuvenate the tube for a temporary stay but it will eventually fail for good and in a short period of time it will be one or the other - - VERY expensive to repair or off to the dump...
Please don't kill the messenger!
William Rayburn, CET
Premium Technologies
Testimonial: "Thank you for your quick response."
