Question about Compaq Evo N610C Notebook
I can´t turn it on
I´ve turned my N610c on on battery (meeting). It went to sleep (still on meeting), so I closed it and went to office. When I tried to turn it on again on charger, only thing that happend - charge LED goes off... When I reconnect the charger, the charge LED goes on again, but pushing any switch turns it off again (only the LED).
How do I turn it on?
  • Ing. Jan Bortel Dec 03, 2007
    I can´t get to windows! It won´t turn on at all... Only tihng "working" on computer now is "charging LED".
    Any other ideas?
    Latest news - laptop is totaly dead - no reaction on power adapter conected or unconected. Battery showing 3 points of 5, but no use.
    Problem Solver:
  • 15 Answers
TurboJumbo,
Try this. Remove the main battery. Then plug the adapter into the unit. The unit should power up. If not then there is still a problem. To continue troubleshooting, Remove parts one at time and plug in the adapter until you get it powering up. By removing parts, I mean, remove the HDD, remove memory, remove the modem, disconnect the LCD, remove the keyboard etc. Order is not important.
Posted on Dec 07, 2007
    Sergeant:
    Champion:
  • 270 Answers
Check ur pwer plan settins in windows xp chose default settings
Posted on Dec 03, 2007
SOURCE:
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
My nokia n900 got wet when it was on and i didn't took out the battery for some while after that i cleaned all teh outer parts with tissue paper then again i tried to turn it on but it just didn&#
Hi once if a phone gets wet, it is very much risk if we don't put off the battery immediately .Because,as and electronics device it is run by current,when it gets wet the different components(parts) with different current (+ve and -ve) are sort.So, when we put battery/charger the internal components easily fused....So, the first aid is to put off the battery and contact mobile repairing shop.It could not be tried easily.....Therefore, I advise you to do not put the battery again,unless you visit mobile repairing shop.If you are trying to power it on by yourself repeatedly without any knowledge,most of the components may damage more worse.Good luck.Thanks for visiting fixya
Jul 02, 2012 | Nokia N900 Smartphone
My display screen goes on and off
I find sleep mode nothing but trouble, eventually corrupts window files over extended use, go into power options, go to stand by and select never and click apply, next go to hibernate "top right" and click, make sure the check box is clear, if not! remove check and click apply and restart your laptop.
Apr 04, 2012 | Sony VAIO Computers & Internet
My laptop battery/preparing to hibernate
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
if it boots up to your operating system
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
Mar 07, 2010 | Samsung NC10-14ROBL Notebook
My compaq evo n610c switches itself on when the
Disconnect the power cable from the Notebook and then remove the Battery pack. While the Battery pack is removed, press and hold the power button on the Notebook for 15 seconds.
Next, reinsert the Battery pack and connect the power cord to the Notebook and turn it ON. While the Computer is booting, you can view the information on the bottom of the screen to get to the Setup Screen.
On the Setup screen, use the right arrow key to highlight the "Exit" menu, then select the option "load/get default" and press the Enter key followed by F10 keypress to reset the BIOS and save and exit the screen.
Feb 26, 2010 | Compaq Evo N610C Notebook
Laptop went into sleep mode and will not turn back on
Try a Hard Reset, follow the steps below:
1) Unplug the AC Adapter from the notebook PC and remove from any port replicator or docking station.
2) Remove the battery from the notebook battery compartment
3) Press and hold the power button for about 20 seconds
NOTE: Holding down the power button while the computer is turned off drains any residual charge in the capacitors
4) Insert battery and plug the AC Adapter back into the notebook PC.
5) Press the power button to turn the notebook PC back on.
Dec 28, 2009 | HP G60-120US Laptop
I have a brand new acer aspire one. A moment ago, when I wanted to open it, I saw that the green light on its top right, that is, at its "start" button was on, and the battery was a bit displaced at one...
Most likely your laptop is going into sleep mode. Lots of them do not like sleep mode if nothing happens when you push the power button try to hold it down for about 5 sec. your computer should power off and then you can start as normal. If this problem persists change the options in your control panel to turn sleep mode off. That should solve it.
Dec 18, 2008 | Computers & Internet
Powered off.
Any beeps when you turn it on? unplug everything and then plug it back in. Make sure the monitor connections are good and that you have it turned on. Again make sure it's turned on. Sometimes it's the simple stuff. Was the monitor working well before it failed? Do you have a video card?
Remove the battery, AC, count to ten and try one last time?
Jan 01, 2008 | Compaq Evo N610C Notebook
Compaq Evo N610C Notebook Logo
109 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
