To insert Sim Card in a Panasonic CF-H2, you need to open battery compartment 1 and remove battery, you will see where the Sim Card inserts, place the sim card gold side up in the depression. Slide sim card down the depression toward the sim slot, slide down till it clicks in place. Re-insert battery 1. Sim card inserted.
Make sure you arwe using it with a 02 handset. If not please try it with one. I would take the sim back to the store or put a call into o2 they should replace you sim card free of charge.Thanks
Hi, How to correct sim card error / insert sim card
Procedure to follow
Step 1: Check the sim tray or sim seater to see if it it broken, if it is, replace it Step 2: If the sim seater/tray is not broken, clean the entire terminal. Step
3: If the sim seater/tray is not directly on the board, trace the
broken led and solder it, or you replace the broken led with another
sim tray. Step 4: If it is still not working, change the battery and
put a new battery, because a virus infected battery will always give
such problem. Step 5: Finally, if the problem still persist, then
check the sim card and replace with another sim card if the former is
bad because a bad sim card will always display such message as insert
sim card or sim card error.
I have a 2001 boxster and could not get the phone to work,
it would not get past insert sim massage.
I have a o2 card stuck in any old credit card size card sim holder ie new cards come like this before you pop your sim out to fit in a phone.. all it was to get it to work was the eject button above the sim slot had not come fully out when sim was inserted got my nail under it and pulled it out further while sim inserted ha presto it now works fine with the o2 card pay as u go hope this helps any one
1. If it is a new sim card wait till the service provider registers the sim. 2. If it was already working previously insert another known working sim card. If same message comes clean the contact points on the cell phone. 3. If above 2 dont work your phone IC is corrupted and you need expert help.
please Hard Reset and find the Network Automatically. and make sure the Phone is on in the wireless manager.
Otherwise there might be a Hardware problem!!
