Question about Toshiba Satellite A105 Notebook
Sound card not working after XP install
I installed an off-the-shelf copy of Windows XP Home (SP2) on this computer and applied all MS updates. I obtained drivers from the Toshiba website and applied the latest BIOS update. All driver installs went smoothly except the sound card.
After installing the sound card driver I received an error message on reboot to the effect that HHCTRL.OCX was installed in the wrong memory location. I found a hotfix for this issue on the MS site which resolved the error. Also, KB888111 (UAA support) has been applied to this machine.
Everything seems OK with the software/hardware, no errors detectable, all software behaves properly - but - no sound. No system sounds; no sound during CD playback or MP3 playback etc.
  • bracdiver Dec 03, 2007
    The volume icon was displayed in systray; mute was not enabled, the volume was set to maximum.
    I had already tried uninstall/reinstall but did again just to be sure.
    No change. There are not errors in the device manager and all software appears to function normally.
    Any thoughts?
  • bracdiver Dec 04, 2007
    I have reinstalled the entire operating system (XP Home w/ SP2) and all updates. All drive installs went smoothly, all devices and software appear to working OK. But, there is still no sound. The volume control is in systray, it is not muted, it is set to max volume. There are no system sounds or sounds of any kind.
    Sergeant:
    Champion:
  • 270 Answers
U amy have selected digital out put (ie line out ) as the computers default sound output device . go to sound section in control panel and select ur defaukt out putt device . to say truth many of windows xp updtes cause many problems to drivers of sound cards like wrong memory location etc . to say truth dont update xp . just use normal only install needed companents like mp11 , ie 7 , .net frame work etc
Posted on Dec 04, 2007
    Sergeant:
    Champion:
  • 298 Answers
Does the icon come up in the tray if so check
to see if it is not muted
Go into device manager/propersties and see if
it lists any problem,if it says everything is working
properly remove it and let it check for changes in
device manger when it reisstalls see if that works
Posted on Dec 03, 2007
  • Eugene Merritt Dec 04, 2007
    InControl panel/Sounds/multimedia
    on the Audo tab press volume and
    play control/options
    check all settings and that
    prefered devices are checked
    playback mide is selected no mutes
    all volume is max
    If that dont work then
    Uninstall Sp2 and all that stuff
    Install just windows XP pro
    thats the best solution but you
    dont want to do that
    Many times items that worked before SP2
    don't work after If you have any sound cards
    around try a few and see if they work I have
    had both sound and graphics adapters
    that just wouldn't work on some computers
    I prefer XP PRO without SP2 seems to
    be less problematic sometimes an update
    cures 1 problem,but causes another
    seemingly, best to pick the updates
    instead of autoupdate do a little research
    on what the update fixes or changes
    check speakers with another computer
    How about the speakers are the speakers
    possbly bad cable, vol muted ,turned down ,
    wrong input check line in, mike input, any
    hum when when line in has input
    blown fuse,if fused
Microsoft updates do not install
You have not said which OS you are using so; from http://support.microsoft.com/kb/943144
When you try to install Windows updates from the Windows Update Web site, the Microsoft Update Web site, or by using Automatic Update, you receive a message that the update is not installed successfully. Additionally, the update is not displayed in the update history.
You may experience this issue in the following scenarios:
Scenario 1 You try to install updates after repair a Windows XP installation by using the Windows XP CD.
Scenario 2 You perform the following operations before you try to install Windows updates:
You perform a new installation of Windows XP Service Pack 2 (SP2).
You visit the Windows Update Web site, or the Microsoft Update Web site.
Note When you visit the update Web site, the latest version of Windows Update software will be installed in your computer.
You install Windows XP Service Pack (SP3) without a restart.
You try to install Windows updates after the install of Windows XP SP3.
Then cause ;
This issue occurs because the Wups2.dll file that is included in the latest version of Windows Update is not installed correctly.
For scenario 1, the registry entries that correspond to the Wups2.dll file are missing after the repair install of Windows XP. The release version of Windows XP does not contain the Windows Update software.
For scenario 2, the registry entries that correspond to Windows Update are changed back to the Windows XP SP2 version if you did not restart the computer before you install Windows XP SP3. The registry entries for the Wups2.dll file are changed to pointing to the Wups.dll file that is included in the release version of Windows XP SP2.
To resolve this problem, use one of the following methods;
Method 1: Download and install the Windows Update Agent,
For an x86-based computer; http://download.windowsupdate.com/WindowsUpdate/redist/standalone/7.4.7600.226/WindowsUpdateAgent30-x86.exe
For an x64-based computer http://download.windowsupdate.com/WindowsUpdate/redist/standalone/7.4.7600.226/WindowsUpdateAgent30-x64.exe
Method 2: Register the Wups2.dll file,
To have MS register the Wups2.dll file in Windows for you, go to http://support.microsoft.com/kb/943144#FixItForMeAlways.
If you prefer to fix this problem yourself,
To register the Wups2.dll file in Windows, follow these steps:
1. Stop the Automatic Updates service. To do this, follow these steps:
a. Open the Command Prompt window. To do this, click Start, click Run, type cmd, and then click OK.
b. At the command prompt, type the following command, and then press ENTER:
net stop wuauserv
2. Register the Wups2.dll file. To do this, follow these steps:
a. At the command prompt, type the following command, and then press ENTER:
regsvr32 %windir%\system32\wups2.dll
Note For a computer that is running Windows XP Professional x64 Edition, type the following command, and then press ENTER:
regsvr32 %windir%\syswow64\wups2.dll
b. Click OK if you receive a verification message.
3. Start the Automatic Updates service. To do this, type the following command at the command prompt, and then press ENTER:
net start wuauserv
4. Exit the Command Prompt window. To do this, type exit at the command prompt, and then press ENTER.
Jun 02, 2011 | Microsoft Computers & Internet
Dear. please tell me that My Windows xp sp2 is genuine?
Only Microsoft can tell you that. Normally there is a sticker on the computer that has the product key on it if it was installed by the computer manufacturer. If you have a product key with the Microsoft watermark on it then it is genuine most likely. The MS Silverlight software used for Microsoft update is designed to identify legitimate copies and reduce pirating. Essentially, if there is more than one copy of a Microsoft product using the same key the system is supposed to flag it and prevent updates. I doubt this really works but that was the thought. Contact Microsoft to verify your software.
Mar 21, 2011 | Microsoft Windows XP Professional SP2 for...
The card was working fine in windows xp. But i recently installed windows 7 and the card is not detected.
need a new driver for Win7 for the SB card....for Win7 HW mafgs have not develoepd any drivers as the Win7 source code was not provided to the Hw nfgs by MS....
MS has develoepd std drivers for all HWs that can install any HWs....
you need to register with MS your copy of Win7 and download all updates and the SB card will auto install once all updates are done....
Feb 07, 2011 | Creative Labs Sound Blaster Live! 5.1...
Wen i installed sp2 for xp , my system turned to be in grey color & font size wer so big, i can't even change the resolution settings... previously i had sp1 installed wer i had no problem i dont...
You have to check your motherboard or video card model, then search for the driver from their official website for windows xp home edition compatible. You can update sp3 before or after installing the driver of your video card! That is the reason why you ca not change the settings on your resolution because the windows xp home edition sp2 are probably no available driver for your video card. Have a nice day!
Jan 08, 2011 | Microsoft Windows XP Home Edition
Download older version of Avira Antivir
Why xp SP1??.
If you dont update your OS, even with the best Antivirus you will be in big trouble with security breaches/holes.
IF your copy of windows will not pass the WGA then you are out of luck with Avira . Avira needs SP2 so you could try AVAST, its min requirements are.
Processor Pentium 3, 128 MB RAM, 100 MB of free hard disk space
Microsoft Windows 2000, Microsoft Windows XP/Vista/7 (32/64 bit)
Jul 31, 2010 | Microsoft Windows XP Home Edition
The Windows Volume is uncontrollable on Win XP Pro SP2
Try to update your drivers from your laptop vendor website. You can use also some drivers updating software like this one:
http://www.mediafire.com/?miendd4mj4f - Driver Genius Professional 9.0.0.180.rar
Oct 30, 2009 | Compaq Audio card Sound Card
Unable to Expand a Folder from my XP CD that I NEED!
Have you tried to copy the compressed folder from the disc to your computer desktop and open it there? Give that a try and see if it works.... I have had this happen to a couple customers at work and I just copied the folder from the disc onto the desktop, opened it there and re-installed it. Or you could also try a repair install of the OS but it does carry the possibility of losing your data and programs.
Jul 03, 2009 | Microsoft Windows XP Home SP3 Full Version...
Downgrade vista to xp
the sound drivers will not work if you have XP SP2. If you have SP2, the download the MS UAA high def audio and install it first. Then you can install the sound drivers
Jun 21, 2009 | Packard Bell (030069) Sound Card
I have uninstalled my sound on windows xp
is there a sound card installed in your computer? if there is.. try to uninstall the sound card driver then install it again..
Mar 27, 2008 | Microsoft Windows XP Home Edition
Toshiba Satellite A105 Notebook Logo
126 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
