Need to use cause my gas water packed up. emersion makes loud bubbly noises and water is very very hot cant turn it down am scared it will blow up. my radiators work on my heating system its a suprima but the water does not get hot so have to use emersion which when you turn it on sounds like a aeroplane taking off
Sounds like head gasket has gone. Hot gas from the fuel combustion is being forced through holes in the head gasket into the cooling system, causing hot bubbles in the coolant, sniff the bubbles blowing out of the reservoir, does it smell like fuel?
it could be two things... a heater hose has worn out or got cut in someway or the heater core is bad and needs to be replaced...that could also cause you to smell some antifreeze in the car and the over heating problem should be that there is still some air in the system after your mechanic changed the thermostat...so some air bubbles might be in the thermostat and then it gets over heated...when the air bubbles get out of the thermostat then the car stops over heating... so let your mechanic remove all the air from the system in order for the car to run perfect... it shouldn't be harmful to your wife and kids...but you should try to fix the problem asap :) Good Luck!
did you size the gas line properly? sometimes if the gas pipe isn't sized properly it will cause some pretty loud wistling noises. also if you have something in the fan like bugs or lots of dust it will cause alot of problems with noises
do you have aftermarket bug deflector and or rain guards? these can cause noise you are describing. also you can turn fan on high fresh air mode and spray doors and windshield with soapy water, if there is a gap air will be escaoing and you will see bubbles
Sounds like you may have a motor issue, they can get lint trapped inside, and it causes the motor to overheat, and eventually go out. You can remove the top, then the front, and see if thats the problem. Usually, once the motor starts making noise, its time to replace. Right now, the packings in the motor are cold, and once they heat up, they stop making noise, so it could last quite a while.
