Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca d52w20 i had a power outage. when the power came back on my tv will not turn on. the green power light will come on for about 3 seconds then turn off. can you help me please. thanks dave
    President:
  • 4,402 Answers
If you had a power surge from the outage it could be anything. disconnect from the house power and try again in an hour.
Posted on Dec 03, 2007
SOURCE:
Green Screen, No Sound, Shuts off after 10 seconds
Almost certainly the green picture tube is shorted. This is a very expensive repair; probably not worth doing.
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA model# D52W20. The TV will not power up.
ON the deflection board ck capacitors 114,130,150 if 150 is puffed up on top it is bad 2200uf 16v use 25v and the other 2 are 220uf 35v replace all 3 of them and resolder around all pinns on FBT flyback transfomer.
Apr 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv light turns on and off ,TV never actually comes on.
CK capacitor cp114,120,150 if ant of these caps are puffed up on top it is bad so replace all 3 capacitors cp 150 is 2200uf 16v other two are 220uf 35v
Feb 15, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA d52w20 Power Problem
ore there ares some ribbon cables that need to be reseated going from the deflection board to the signal board
Nov 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
[email protected]
Jul 18, 2008 | RCA HD52W58 52" TV
RCA TV Will Not Power On - Powered Off Suddenly
Theses sets had 2 problems pip mod or most of the time Flyback Transfomer bad.
Jul 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv wont turn on
I am having the same issue. I think it's the bulb.
Aug 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
99 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
