Question about MSI MS-1012 Notebook
LCd open in certain angles makes screen darker and sound disappear/noisy
After 14 month of usage - the lcd started getting darker when in certain open positions. I "fixed" it by changing the angle of the lcd - now it seems to be a lot more open positions that makes the display dark, and the sound too is disappearing or getting noisy when display is open in certain angles. I suspect bad wiring but I dont have a clue how to open the chassis without breaking it.
  • 4 Answers
Its natural dude....
laptop dnt hv long lives
neither do the batteris hv
try to change the batteries
Posted on Jan 10, 2008
SOURCE:
Faulty lcd screen connection elliptic pattern
if you loose picture when the "lid" is at certain angles it could be the LCD panel but I would lean more towards an LVDS cable issue (aka lcd cabkle).
Jan 04, 2014 | Computers & Internet
My HP laptop starts with a white screen then fuzzes sometimes in between
Try to remove your LCD monitor check all connector must be connected properly, sometimes this happen if connector got lost contact.
If problem persist contact advance knowledge in trouble shooting Laptop monitor. This problem occurred when the bulb of LCD got Trouble.
Jan 14, 2013 | HP Computers & Internet
Hello. My Samsung LCD model # LN-T3253H 60"/61"
It sounds like your LCD panel or your T-con board is bad . Panels are expensive so I would replace the T-con board first. You have to open the TV and get the part number from the actual board in order to find the correct one. You can find parts at www.interliquidparts.com
Jun 03, 2011 | Samsung LN-T3253H 32 in. LCD Television
Everything that displays on the screen now has a bluish hue and flickers at certain angles, model 3694
the lcd is starting to go bad it sounds like. Call Acer Support to get it serviced if your laptop is still under warranty.
If your laptop is not under warranty then you'll need to find a place to buy the lcd and get it replaced, this site has the screen for your laptop:
http://www.lcds4less.com/AcerLaptop__Acer_Aspire_3690_Series__laptop-screens.html
You can do a search thru google and find more as well.
Jan 22, 2010 | Acer Computers & Internet
LCD Display problem
From your description it sound like you have a faulty video cable or the video connector on the motherboard is loose.
Reseat the connector and it may solve your problem.
Jul 13, 2009 | IBM Computers & Internet
I am not able to open my laptop, when I tried to open the screen it makes some noise as if something is getting crushed
If you are trying to disassemble the LCD screen and hear cracking sounds then - the crushing/cracking sound is most likely that you have cracked the LCD screen in several places. If you look at an acute angle you will see cracks in the LCD screen.
Replace screens are available at LCD Parts, they supply parts, repair service and DIY info. Use this link to their WEB site.
www.lcdparts.net
Jun 28, 2009 | Lenovo IdeaPad Y510 Notebook
Screen Half darker
It sounds like your backlight isn't working properly. LCD screens have backlights that illuminate the colors produced upon their surfaces, so that you can easily see the screen without an external light source. In your case, it sounds like your backlights either aren't cailbrated, are damaged, or were produced unevenly.
There is most likely not a fix for this, though most all LCD screens have some form of light distortion. My own LCD screen is slightly brighter around the edges, where the backlights are located, but this is only noticeable when displaying a completely black screen.
Jun 22, 2009 | LG 22" FLATRON LCD Monitor
Darker fatter letters every 2 inches apart from top to bottom
it is called phase you can attempt to let the lcd monitor auto set or you can disconnect the power over night then plug in and then do not auto set this default usually seems best some times
Nov 29, 2008 | Proview PL926WBi 19" LCD Monitor
Sound but, no picture
it could be the main, x or y, or buffer board
Jul 23, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
MSI MS-1012 Notebook Logo
120 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
