Question about Panasonic DVD-LA95 Portable DVD Player
PANASONIC PORTABLE DVD PLAYER ERROR CODE 3. MODEL NUMBER LS5
Can any one please help, my colleageue at work has a the above model player displaying error code 3. Do you or any of the other guys have any idea how to correct this please.
Many thanks
George.
  • 3 Answers
This could be the laser going or a dirty track. I suggest that you first clean the laser gently. If this doesn't work you must take the player apart and clean the track that the laser moves on along with everything around it (keeping in mind that the laser is fragile).
Posted on Apr 01, 2008
SOURCE:
Whate causes Error H03 on a PANASONIC DVD-LS5?
the is not able to read the disk that's why you get that error message.the cause of error reading disk are busted dvd lens and the spindle motor it is the motor that holding the disk and spins .first try to replace the motor you can buy that in an electronics supply store next is try to replace the lens
Jul 17, 2010 | Panasonic DVD-LS5 Portable DVD Player with...
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
HO2 error code at screen
In line with the other Panansonic DVD players, the error seems to relate to the internal drive machanism getting stuck.
To fix you just need to carefully take the back off (disconnect power source first!), locate the drive cogs for the lens machanism and give the a couple of turns. Also a blast from a air can will help get rid of any dust build up. Pop the back cover back on and you should be working.
Looking at the other Panasonic threads on the site, this may happen on a regular basis especially as the unit gets older (and the crud builds up).
Jul 10, 2008 | Panasonic DVD-LS5 Portable DVD Player with...
DVD-LS5 portable
The spindle motor is defective.
Mar 21, 2008 | Panasonic DVD-LS50 Portable DVD Player
Black Screen
If the LCD screen is not broken.the LCD backlight probably went out when it got dropped. Need to take it to a service center to get it looked at.
Mar 19, 2008 | Panasonic DVD-LS5 Portable DVD Player with...
HO3
See my post on this http://www.fixya.com/support/t160505-hd03_error
Jul 28, 2007 | Panasonic DVD-LS5 Portable DVD Player with...
CODE HO3
check my response here http://www.fixya.com/support/t160505-hd03_error
Feb 20, 2007 | Panasonic DVD-LS5 Portable DVD Player with...
Panasonic DVD-LA95 Portable DVD Player Logo
76 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
