Question about Pioneer DVR-520H DVD Recorder
Pioneer vsx 808 rds poweroff?
I have a pioneer vsx 808 rds that powers off when its turned on would you know whats causingt this as the repair centre dont know what it is without looking and i dont want to start paying money on somethink that cant be fixed cheers mat
    President:
  • 4,402 Answers
Could be lots of things, could be the tray not fully loading, or power supply problem...
Posted on Dec 03, 2007
SOURCE:
Overload pioneer vsx 808 rds
if it's shutting down when you increase the volume, this usually indicates a bad speaker.
Jul 03, 2013 | Audio Players & Recorders
Poweroff indication with no output
Have you tried the owners manual (not the repair manual)? It will probably have something about this. It may be that this is the generic message that the unit gives you when you have a bad output channel which would put it into a protection mode.
Jul 29, 2007 | Pioneer VSX-406 Receiver
VSX-D457 Display's power off and then shutdown
Most likely it needs one of the output ICs. But check for cold solder rings on the ground connections of the input board. Est. for it to be repaired $100-$120
Dec 17, 2009 | Pioneer VSX-D457 Receiver
I have a VSX D710S and it flashes poweroff then
Im having this same problem. It happened after I had the music up really loud for about 3 hours. Also, where it has the volume all i see is -- instead of a number when i try to turn it on
Nov 29, 2009 | Pioneer VSX-D906S Receiver
I have receiver VSX-D509S. Have had it for
Check for a bad ground on the input circuit board. you will need to re-solder them. Remove top cover and rear panel (many screws on rear panel) The input board can easily be accessed and resoldered. you should also check for a bad ground on the speaker jacks. If it is not repaired, sooner or later you will probably need an output IC. good luck.
Oct 16, 2009 | Pioneer VSX-D509S Receiver
VSX-D308
Maybe the audio amplifier IC is damaged and you gotta change it.Good luck.
May 26, 2008 | Pioneer VSX-D308 Receiver
PIONEER VSX D810S POWEROFF
Hay que chequear los alambres de los parlantes..yo tuve el mismo problema..desconectè todos los alambres de los altavoces y luego los reconectè...y allì estuvo la soluciòn...
Mar 30, 2008 | Pioneer VSX-D810S Receiver
Pioneer vsx-456
I have um Acquitance Groundbreaking VSX -456 as you I turn on appears Poweroff and he turns off automatically if he may go feasible ma ajudem,pois did not what to do. thank you Awaiting recurrence for its email: [email protected]
Nov 20, 2007 | Pioneer VSX-456 Receiver
Vsx-d506s problem
It may be a PROTECT MODE. Check is your other equipment properly connected to receiver.
Oct 09, 2007 | Pioneer VSX-D506S Receiver
POWER OFF alert
When you turn on receiver it will power off. Poweroff shows up and than turns off. if the front panal reads over load the output ic pac001a is defective i had repaired this model before
May 29, 2007 | Pioneer VSX-D710S Receiver
Pioneer DVR-520H DVD Recorder Logo
705 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
