Question about Vulcan 260L Gas Kitchen Range
Vulcan 260L Gas Commerical range
My grill top turns brown when used. requires constant cleaning. Any ideas
  • busyone Dec 05, 2007
    Sorry maybe didn't explain this is a resturant griddle or grill that I have taken over. And this type of discoloration is not normal after just frying a few pieces of bacon or sausage, and it does cause the food to stick very bad. Of course it is sprayed with a cooking spray before use. Thanks for trying, but that is not the answer to my problem.
  • busyone Dec 06, 2007
    I am not sure this is made of cast iron. I have been told it is made of steel (ground or something) If I had anyway to know what it is made of that would be a help I am sure.
  • 640 Answers
Busyone,is only one part of the griddle getting discolored?if so you most likely have a bad thermostat.otherwise i would agree what bob from li said.
Posted on Dec 29, 2007
  • 833 Answers
I'm assuming you're speaking about a meat grill or another grill in contact with food. It is generally made of cast iron. This discoloration is normal and is caused by fats impregnating the grill. In practice, this will prevent sticking of food in the future. Grills should always be seasoned with a small amount of oil or fats and cooked on. They are cleaned with a mild soap solution after use but not scrubbed to a shine. If you do not like the look, simply wipe the grill with a small amount of cooking oil.
Posted on Dec 03, 2007
  • Robert Hirst Dec 05, 2007
    busy...my comment still stands. To that, I'll add that cooking sprays are not suitable for what you are doing. Some have low temp oils in them that oxidize. That's what you're seeing. You should be using commercial products which are made for grills. The other possibility...although low, is that you're overheating the grill.
What is the best way to clean the flat top griddle?
Wow that is a loaded question. Everybody seems to do it differently. I will give you my two cents. Start with a medium hot grill. Throw on a little clear water and steam off the bigger gunk and scrape it down. (I have heard that sprite or 7-up or ginger ale work real well here too). After that mix together about two cups of water (some people use cooking oil instead of water) and 3/4 to 1 cup of vinegar and pour that on slowly while scrubbing the grill with a Grill Brick (Lava Brick) This is where you are really doing the work. Scrub until clean -- may take a while. When done use a rag dampened with clean cooking oil to wipe down the grill and leave a little sheen on top.
Dec 09, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
No gas trough the 1/2 psi regulator
If you have gas up to the regulator and not after it then you need to replace it.
I have taken them off and cleaned them with hot soapy water, dried throughly and reinstalled for a temporary fix, but do not recommend it for a long term.
Seems that the grease from the kitchen envioronment can get in there and gum them up causing them not to work over time.
Heatman101
Jan 21, 2010 | Vulcan 260L Gas Kitchen Range
Cleaning a grill
Vulcan has an online site that allows you to down load the operation manual for just about every model... here' s link... their op manual looks pretty helpful!
Vulcan site
May 24, 2009 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
How do i adjust oven pilot light on vulcan range
hi, there is an orfice for the oven located on the gas valve. If you are using LP gas, the orfice should be turn down all the way (counter clockwise). If you are using natural gas, the orfice should be turned out about 2-1/2 turns. Was this oven set up to be used with one gas and noe is being used with another? If so, you will need to do more then adjust orfices. Please let me know if I can assist you further.
Thaks
Vic
May 13, 2009 | Kitchen Ranges
Coverting a Vulcan 260L commercial range to Propane
Yes you can convert to LP gas. go to this web site to get the parts.
http://www.vulcanhart.com/manuals/F-30536.pdf
Go to page 9 and look at parts # 57 - 60 that is the part you need to change. You need to know the sea level that you are at though so you get the right part.
Now if you go to page 8 you will find where it goes part # 53 thru 61
To order the parts go to this web site
http://www.vulcanhart.com/parts.cfm
If any ? please fill free to ask.
Dec 17, 2008 | Vulcan 260L Gas Kitchen Range
Vulcan 260L Gas Kitchen Range Logo
316 people viewed this question
Top Vulcan Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Vulcan Kitchen Range Expert? Answer questions, earn points and help others
