Oven is approx 6 yrs old. when it gets to a certain temp it displays F2, beeps and turns off. I have retried to start it up again and it does not work.
Hi~ According to the manual for this oven, the F2 code signifies - high oven temperature. The only suggestion for any of the codes in the manual is to disconnect the electrical supply. It says" pressing OVEN CANCEL pad or disconnecting electrical supply may eliminate "F code". If failure continues, contact an authorized servicer.
I hope this helps. Linda
Hello there" The F 2 error that you are getting is telling you that the temperature sensor is going bad and needs to be replaced the temperature sensor is what senses the ovens temperature say you have it set for 350 when it is at 350 the sensor tells the oven to stop heating up and when it gets to a certain temp below that value it will make the oven heat up again it looks like this
Hello there: Normally this is due to a bad temperature sensor
F3
Open oven
temperature sensor
circuit
Measure oven
temperature sensor
circuit at oven temperature sensor (should be approx
1100
ohms at room temp); check for cut or pinched wire or
loss
of contact and replace if found faulty
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below: Appliance Repair Help With Live Chat
F3 is Open oven temperature sensor
circuit. F4 Shorted oven temperature sensor
circuit . F7 Component failure.
To fix this you need to read oven temperature sensor
circuit at oven temperature sensor ( approx 1000
ohms at room temp); check for cut or pinched wire or loss
of contact, if wirings are ok, then replace the probe.
F2 is Oven sensor is out of range .. oven sensor is sending a reading that the control can not understand... replace oven sensor and you may have to replace the control too as it may not be reading correctly... good luck and let me know if it helps
jaz3133, it's probably the temp sensor that has gone bad. You should be able to get it from the front. It's the probe that comes out from the back wall of the oven. You can have someone ohm it out. Should read approx 1100 ohms at room temp. Part number for the temp sensor is WB20K5040. Make sure power is off befor removing the sensor. Catriver..post back.
display will partially work certain buttons will not
