Question about Dell PowerEdge 1800 Server
Dell Poweredge 1800 megaraid Error
Hello Dear,
I am using Dell poweredge 1800 Server machine with Linux 3AS. I am facing a problem with the Error that exactly i can't wrote but the error is like "Megaraid Error: Can't Reset....." and then its give "I/O Error: Dev XXXXXXX Sector XXXXX" this error it give on so many time with different sector numbers and then gone into HANG position... when i Restar the Machine it will run Normally .. Can u please help me how could i resolve it, is that raid controller error or some OS error
Please Help ...
Aleem Asghar
  • 22 Answers
Re: Dell Poweredge 1800 megaraid Error
I'm glad to hear your using Linux. It sounds to me like you have bad sectors on your Hard Drive but I can't be sure from what you describe above. I need more info. Is it hda sdb or what? dev What? I'm pretty sure it's a hardware problem. Most of the time a Linux server only goes down if there is a hardware malfunction. dev is a device. The question is what device.
Posted on Dec 10, 2007
0 characters
3 Points
Dell Poweredge 1800 server not start, i press power button but nothing hapened
Your Model of Dell Poweredge 1800 server may not have a redundant power supply. The power supply is the most like cause of the problem. order a replacement power supply and replace the faulty unit.
Oct 17, 2011 | Dell PowerEdge 1800 Server
No power on my PowerEdge 1800 Server
dells power supplies must come from dell. I would call dell and give then the service tag number of your server and they will be able to tell you about how much a power supply is.
May 02, 2010 | Dell PowerEdge 1800 Server
Hello, my dell poweredge 1800 does not see up than 256MB RAM, how I can fix it? I have 1GB RAM on the board...
Check the RAM frequency of the RAM which should be compatible to the main board. also chk for the other RAM frequency also
Nov 20, 2009 | Dell PowerEdge 1800 Server
Flshing Red Light on Dell Poweredge 1800 Server
I finally made contact with our IT dept who were abole to carry out a remote diagnostic test.
Problem has now been identified (problem with tape drive)
Jun 10, 2009 | Dell PowerEdge 1800 Server
I looked over the spesifications for the poweredge 1800 servers, go ahead, it will work perfectly but there is one problem in the windows XP setup, you will need to insert / load SCSI or SATA drivers for the hard drive With a floppy disk, or if you don't have a floppy drive your going to need to create a custom windows xp setup cd and add the drivers into it so it can start the SCSI or SATA hard drive and finish the install. without the drivers it might not find the hard drive.
Aside from that I don't see any other problems. You should be able to get the drivers, and everything ese from dell site
Actually I looked over the dell downloads, I see only windows 2000 on the list with windows server 2003, and 2008 and linux distributions.
This could be a 2nd problem, drivers might not be avaialble, or work with xp, but we might be able to get it to work.
So two problems, SCSI or SATA drivers in windows xp / windows 2000 setup
2nd problem is in windows xp drivers, you could try windows 2003's drivers and 2000's and see if they work, if not, then we would have to look for drivers ourselfs from the internet.
So xp might cause headache but we might get it working, windows 2000 seems to be supported perfectly.
Let me know how the project goes
Jun 03, 2009 | Dell PowerEdge 1800 Server
Dell poweredge 1800 scsi drive not found
check if the drive is showing in the bios of the server,
shut down the server, take out the power cable, press and hold the power button so as to realease flea power, open the server, and reseat the data cable at both ends and if there is another power cable available in the server swap it with the existing cable plugged into the scsi drive.
and now try to start your server.
Further Queries are welcome
Feb 26, 2009 | Dell PowerEdge 1800 Server
Dell server poweredge 1800 frequently shutdown
is there an error message that appears? can you check error logs? I need more information to be able to help you. I would first try to blow dust out of the fans, as it may be over heating, another possibility is that there is software on the machine that is causing it to shut down.
Mar 17, 2008 | Dell PowerEdge 1800 Server
Dell PowerEdge 1800
Hi satti73,
I need you to explain your problem a little more clearly.
I think you are saying that when you press the ON/OFF you get a display? What is the display that you get? How old is this machine? What other events have taken place leading up to this problem. Do you get and error messages on the monitor? DO you get any sort of sound emitting from the server when you press the ON/OFF butoon?
Nov 09, 2007 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1800 Server Logo
491 people viewed this question
Top Dell Computer Servers Experts
Jax Planet
Jax Planet
Shawn DuRee
Edd nugent
Level 1 Expert
Are you a Dell Computer Server Expert? Answer questions, earn points and help others
