How to install seagate ata IV hardrive
The easiest way to upgrade from your old HD to the new 40Gb HD is to clone the old to the new. Do a google for "hard disk clone" freewares. Personally I use Partition Magic and have had very good results.
Hardware wise, you need to install the 40Gb as a slave to the old HD by connecting the same IDE cable as that of the old HD (you may have to remove your CD/DVD temporarily). You also have to temporarily remove the single jumper of the 40Gb to allocate it as a slave to the primary master (old HD). Plug in likewise the 4 wire power connector. On power up go to your CMOS/BIOS setup to verify that your PC autodetect the 40GB (you may have to do a manual detection). Boot your PC and go through the normal boot sequence. Thereafter download your clone software choice, install and run. Follow on screen instructions. You may need to reboot. After completion, use Windows Explorer to verify that everything has been copied. Power down, remove the old HD, relocate IDE cable connector of the old HD to the 40Gb, reconnect your CD/DVD, and place back the jumper of the 40Gb. On popwer up go again to your CMOS/BIOS to verify that the 40Gb & the CD are detected. Save & exit, reboot.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
