My servis M9503 washer/dryer stopped during the spin cycle, the water didn't drain. I think my partner may have slightly overloaded it. I drained the machine by hand and no it stops after the spin cycle and doesn't dry. There is always an inch of water left in the machine when it stops. And this is regardless of what program is selected. Even dry only leaves wet clothes and an inch of water.
If your washer spins but does not pump the water out,
the drain line is probably clogged. In many washers a small sock or
other piece of clothing can get between the clothes tub and the outer
tub that holds the water. If the clothing gets between the tubs, it may
then get into the drain hose that is attached to the pump or even into
the pump itself. It it's in the pump, you need to remove the hoses from
the pump and pull the item out.
To remove the item from the outer tub port, open the
washer's main access panel and remove the large diameter rubber hose
that connects the pump to the bottom of the outer tub. Using a
needle-nose pliers, try to grab and remove the stuck item through the
port.
Check your washer for a frozen pulley. Remove the pump
from the washer and try to rotate the pulley manually. If it doesn't
turn freely, it's frozen, replace it.
If the water that pumps out of the machine goes back
after the spin cycle, your washer is siphoning the water from a laundry
tub that has a slow drain back into the washer. The usual remedy for
this is to improve the draining of the laundry tub.
Also check for these problems:
If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Hoover AAA Whisper 1400 - I can not open the door, the washing is still inside. I have turned it off...
(More)
Hoover AAA Whisper 1400 - I can not open the door, the washing is still inside. I have turned it off and unplugged it presuming the electro magnet would release. Display error is "ERROR 1" How do I release the door?
I am trying to replace the door handle on my Hoover Easy logic 1300AA HP13. How do I reassemble the...
(More)
I am trying to replace the door handle on my Hoover Easy logic 1300AA HP13. How do I reassemble the mechanism?
I started a programme (Sports wash) and then tried to cancel it after about 20 seconds (it had...
(More)
I started a programme (Sports wash) and then tried to cancel it after about 20 seconds (it had started to fill). I have tried to follow the instructions for cancelling the programme but it just keeps going back to the Sports wear programme and won't let me select anything else, neither will it let me continue with the Sports wear programme. Please help as I desperately need to do some washing!
