Question about Magellan RoadMate 700 GPS Receiver
Demo screen When I power the unit on I get a demo explaining everything about the gps unit. I can't exit the semo. I tried to reset it, but nothing happens. I wonder if something might be wrong with the cradle?
  • 50 Answers
Call the magellan company they will help you out,you can get it and try it but may be the unit itself.but call the company before you do anything
Posted on Jan 10, 2008
SOURCE:
My Garmin Nuvi 650 is frozen
try putting 1 finger on lower screen hold and press power botton until its factory dafult reset it should fine. don't worry be happy now
Nov 24, 2017 | GPS
Alarm Demo mode pops up when we try to put in an address and the
Sometimes these will go into demo mode for no apparent reason. You can access the diagnostics screen by holding the map/music button while powering up. Be careful which buttons you press in this mode - select only the on-screen buttons, not the hard-buttons as they adjust brightness and contrast. Select the correct operating mode and power the unit off, then on.
May 13, 2009 | Lowrance Iway 500c GPS Receiver
My Garmin StreetPilot 2730 won't hold its settings.
Do a hard reset.
Turn the unit off, then hold down the menu and map buttons, simultaneously, then turn the unit back on and continue to hold down the buttons down for at least five more seconds, then the unit will power up. At that point it's like the unit is being used for the first time and you will have to reset everything. You will lose your XM presets, but the MP3's were still there.
Also after if this does not work, plug in your garmin and mount it, mac or pc whatever, then go in your garmin file erase all maps should be gmapsupp.img or gmapprom.img. Reload your maps from mapinstall.
Jan 14, 2009 | Garmin StreetPilot 2730 GPS Receiver
Garmin streetpilot 2620 in demo mode
Do you have any unlock code for your unit? Delete this code "demo" from MapSource and put unlock code for your unit and try to download to unit a small part of maps.
Nov 12, 2008 | Garmin StreetPilot 2620 GPS Receiver
Stuck in demo mode
to deactive demo mode press menu on the remote...then w/that screen up push the screen mode little gray button at the top of the remote...note that this will not change anything on the screen...i know weird huh...now type in the numbers 9012 you should now be at a new menu the top opption is demo mode...choose it and then choose on or off...good luck i see this i an old post but i hope it helps someone...
Jul 08, 2008 | Sony DHG-HDD250 200-Hours Video Recorder
Garmin Rino 530 stuck in DEMO MODE
Try a hard reset....with power off hold enter button and page button while turning on unit ....this should reset to factory setup, should now be able to switch out of demo mode
Jun 11, 2008 | Garmin Rino 530 GPS Receiver
Tomtom One screen problem
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Dec 04, 2007 | Tomtom ONE GPS Receiver
GPS IN DEMO MODE
Hahah..
Rabbit,
First off you may want to check what kind of SD card is in the slot. it's underneath the rubber. I haven't worked with the 2000's all that much so I'm not certain if your concern could be fixed by changing a setting in the settings menu of your 2000. Look for the word Demo everywhere!
- Ask more questions if needed... Prior to Rating -
Oct 25, 2007 | Magellan RoadMate 2000 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
67 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
