Question about Lakewood (5500) Oil Filled Radiator Heater
Ticking sound I have this for a year used last winter also 3 months, pulled it out ocer the weekend and turned it on and once warmed up it began to start to make a ticking or clicking sound from the bottom of the unit...
  • Anonymous Jan 27, 2008
    I also bought this heater last winter and have only used it to take the chill off the room on those really cold mornings. It has only been used for a few hours at a time and not that often. The other day it started to heat but was cold when I turn it off. It will not heat at all now. The lights come on. It has never been tipped over or used for long periods.
  • Ronnierob Nov 29, 2008
    I have this same model number heater and used it only for a very short period of time. Purchased at Walmart and now it does not heat at all. The lights come on and that is all it does.
Its natural...its just the sound of the oil warming up inside,it pops for a few minutes
Posted on Dec 03, 2007
SOURCE:
What weight oil to use in the summer in a 2003 pontiac grand am
heavier oils are fine in warm summer months, 10W30 or 10W40-
all cars ran on these oils summer or winter for years. Newer vehicles are designed for 5W oils and you should use a 5W oil for them in the winter months
Jul 15, 2016 | Pontiac Cars & Trucks
Mmy truck makes a whosteling /ticking sound u till it warms up ive notice the oil guage fluctuates between20 and 70 and soumd seems to come from behind carburator could this be th oil sending unit?
Ticking sound coming from engine. What could it be??? [Archive ...
www.plowsite.com > ... > Trucks > Chevy Truck Discussion
Nov 10, 2011 - 14 posts - ‎10 authors
Makes a ticking sound until the engine warms up. ... If I put the truck in park and rev the engine, it doesn't make the ticking noise, but if I put it in ... Even doing an inspection on my truck didn't show the crack in mine last year.
What's That Ticking Sound Coming From Your Car's Engine?
www.popularmechanics.com/.../whats-that-ticking-sound-coming-from-...
Apr 18, 2014 - My engine has developed a strange ticking sound. Its whisper-quiet before an oil change, and then makes a loud tapping ... Even more strange: The engine is muffled when its cold but noisy when its warm. .... Whether they were great or not, these cars have some cool names. By Collin Woodard · Trucks.
Dec 09, 2015 | Cars & Trucks
2009 Ford Flex when started first thing on a cold morning it ticks/knocs really really loud, once it warms up the ticking goes away to a very light tick. The dealership ruled out an exhaust manifold leak....
It does sound like a valve lifter problem to me also. It should be covered under warranty. It's a mechanical failure of a component of the drivetrain. Ask them to show you the specific exclusion if they say it's not a warranty problem.Powertrain warranty is 60 months/60,000 miles ( which ever comes first).
Mar 30, 2011 | 2009 Ford Flex
Instaled new Hampton Maris fan, when turned on loud ticking sound began. Checked connections and did not find any obvious problems
Is the ticking sound the pull chains tapping on the globe? Sometimes when the blades are not balanced then the chains will make a ticking sound.
Dec 13, 2010 | Madison Avenue 04317 Hampton Bay Ceiling...
We have the WH95TP unit on our boat. It has worked great for 10 years. Last weekend there was water leaking from behind the unit. We turned it off and turned the water flow off and left for the week. When...
Was the unit running when it was warm? If it was then you need a tech to look at the sealed system. If it wasnt running then you need to adjust the icemaker ejector blade so its straight up (12 oclock) Thats when it will allow the compressor to come on.
Sep 26, 2009 | U-Line Refrigerator Ice Maker
26 Cu Ft Side By Side Maytag Refrigerator: Relay Failures
you have more than likely got a bad compressor it is pulling to many amps you need to replace the compressor
Jul 12, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
Craftsman 24Hp Lawn tractor engine dying out
1. check the oil level... don't want the auto shut off to be the problem due to low oil level
2. pull the carb bowl and check for residue. Spray out the needle valve in the carb, spray out the bowl and any jet openings you can find...spray them out too.
3.When you winterized, did you put fuel stabilizer in the tank? If not, drain the tank and refill with fresh...
4. check the air filter element and make sure it is clean...
let me know how it goes...
k
May 31, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Kawasaki Vulcan 1500 (not FI) funky sound after shut down
Hi, Yes it is an electric fuel pump and the ticking is the pump working. So if you hear the ticking your pump should be OK. After turning off the petcock and running the carbs dry the next time you turn it back on you should leave the kill switch on and turn the key on and wait till the ticking stops, turn the key off and back on and wait for the ticking to stop again. You should do this a couple of times to make sure the system fills. Normally you should always use your kill switch to turn off your engine. Also under normal conditions you will not hear the ticking as it only ticks a couple of times to fill the system once it is full. Good Luck to you, This should Fixya!
Mar 24, 2009 | 2004 kawasaki VN 1500 Vulcan Classic
The 2000 mountianeer starts and runs fine but shuts off
CHECK THE COLD START ENRICHMENT VALVE AND OR THE IDLE CONTROL VALVE. I AM ASSUMING THAT YOUR VEHICLE IS FUEL INJECTED. ONE OF THOSE HAVE GONE BAD.
Jan 24, 2009 | 2000 Mercury Mountaineer
Sorry...i joined the first problem
When it is a no start does the engine crank over but not start? if so check the fuel pressure sounds like a fuel pump issue.
Nov 22, 2008 | 1996 Mercedes-Benz C-Class
Lakewood (5500) Oil Filled Radiator Heater Logo
628 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Paul Carew
jdthefixer
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
