Question about Samsung HLP5085W 50" Rear Projection HDTV-Ready Television
Dead lamp pictures will not come on. i know the lamp is dead but do you know how to replace it yourself...ie DIY
    Genius:
  • 1,694 Answers
In you owner / operator manual you will find step by step
instructions and cautions as to how to handle the lamp replacement.A plastic door panel will be removable and then a
lock screw loosened and lamp assembly pulled out....Be sure
you purchase the lamp assembly complete, not just the lamp.
Let me know...................................T.
Posted on Dec 03, 2007
How do i know if bulb is bad
firstly, confirm your lamp is AC or DC lamp, then note the front-end of lamp core, whether it reveal the blackened.
generally, if the lamp core was bad, always have some mark on the foot of lamp, carefully check it whether it has some white air bubble.
certianly, if you are convenient, you can DIY a lamp power for testing the lamp by yourself.
Jan 16, 2012 | Dell 1100MP Multimedia Projector
The picture is very dark
Sounds like your lamp/bulb is about ready to die. Here is a google shopping list for some replacements if you choose to DIY. http://www.google.com/search?q=Mitsubishi+WD-60735+replacement+bulb&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a#q=Mitsubishi+WD-60735+replacement+bulb&hl=en&client=firefox-a&hs=XxY&rls=org.mozilla:en-US:official&prmd=ivns&source=univ&tbm=shop&tbo=u&sa=X&ei=k7KtTZP4A4jk0QGYm6jHCw&ved=0CHwQrQQ&biw=1366&bih=650&bav=on.2,or.r_gc.r_pw.&fp=30e0fb8dc28dda8
Also if you need help on the DIY just come back. But a detailed reinstall can be found in the manual starting on page 75 which if you don't have can be found here:http://www.mitsubishi-tv.com/pdf/ownersguides/WD-60735.pdf. Also on that page is a part number and phone number to get replacement direct from Mitsubishi. Good Luck!
Apr 19, 2011 | Mitsubishi WD-60735 Projection Television
I just replaced the lamp on my Samsung HLS5087 and now the TV won't power up. The 3 LEDs are lighting which indicates that the lamp needs to be replaced. I put the old lamp back in to make sure there is...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help to solve the problem,,,,
Dec 06, 2010 | Televison & Video
When I try turning on the TV the power/standby light flashes green until I turn the TV off, no picture appears.
If Sony KF-60WE610 does not show any Red blinking light then it is Lamp that need to be replaced because existing lamp has reached to end of its life but still not dead nor broken and causing problem.
If lamp got dead or broken, tv will show you Lamp light blinking.
Replace lamp in tv to solve its problem.
Hope these info will help you.
Please buy Sony original lamp for good picture in tv.
Let me know if you have any question.
Thanks.
Nov 04, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Lamp light blinking
The problem is that your lamp has expired, You need to either get in touch with the brands authorised repair agent and they can order and replace lamp( at a cost) or you can replace the lamp yourself. Also make sure you know how to rest the lamp use hours after replacing the lamp. Good luck.
Nov 20, 2009 | Toshiba 62HM196 62" SD Television
TV will not turn on.
If it is Sony KDF-E55A20 TV then replace its lamp as symptoms shows lamp is broken/ dead.
lamp replacement procedure is written in user manual and let me know if you have nay further question.
Thanks.
Sep 27, 2009 | Sony KDF-E55A20 55 in. LCD Television
Screen is dead on A105-S4104 laptop. External monitor works fine. How do I check to make sure that there is not just a loose cable?
This could be a faulty video cable or connector or CCFL lamp or inverter.
Try reseating the video cable/connector that connects to the motherboard first.
If this doesn't work then to determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 15, 2009 | Toshiba Satellite A105-S4004 Notebook
My laptop monitor flickers ramdomly....the grafix
This could be a faulty CCFL lamp.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jul 14, 2009 | HP 510 Notebook
When turning on my compaq presario F500 today the screen would not light up. With difficulty, I could vaguely see the IE window boxes & screensaver but cannot get the plasma light to work. Any ideas ? Its'...
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 22, 2009 | Compaq Armada M700 Notebook
Sharp Actius MM10 laptop just went dead
You could have a defective screen, either a faulty inverteror a CCFL lamp - follow this to determine the fault.
Apr 15, 2009 | Sharp Actius MM10 Notebook
Samsung HLP5085W 50" Rear Projection HDTV-Ready Television Logo
57 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
