Rockford Fosgate Punch 401S Car Audio Amplifier
Problem for Rockford Fosgate Punch 401S Car Audio Amplifier
No sound from subs
By birdmanone31 on Aug 22, 2009
i have 2 cerwin vega 15s and a american legacy amp. i have power to the amp but there is no sound from the subs.are they blown?
Solution #1
posted on Aug 22, 2009
Somewhat Helpful)
kirtec
Rank: Guru
Rating: 87%, 464 votes
take a 9 volt battery and touch the speaker terminals quickly.
they should move and make a noise if they are not blown voice coils.
do not leave the voltage on it for more than 1/2 second,as the dc can burn out the speakers coils
Was this helpful?
Yes
No
Solution #2
posted on Aug 28, 2009
Not Rated)
laseramp
Rank: Wiz
Rating: 85%, 92 votes
id say get a test speaker and run the amp on very low output, just see if you get a audio signal from the amp, if so then the problem lies in possibly your speaker wiring terminals, very possibly you had everything working for a bit, and one day the speakers may have hit to hard and the internal wire might have come lose. it;s very common problem and a good crimp job on the terminals will often fix many headaches later, check your speakers with the amp and if it works you know your ok. also turn the sterio off and have a freind listen to the speakers, see if theirs any sound at all when the amp is powered up or the headunit is first turned on.good luck with it. love the idea about the 9 volt battery test their kirtec
Was this helpful?
Yes
No
Popular Solutions for Rockford Fosgate Punch 401S
Questions and Unsolved Problems for Rockford Fosgate Punch 401S
Do you recommend Rockford Fosgate Punch 401S Car Audio Amplifier?
Answer
Answer
i have a pioneer gm-d8400m when the amp is working properly there is a blue light on the front of... (More)
Answer
The premium audio system in my 06 Toyota Solara skips audio in the 6 cd, radio and tape player. All... (More)
Answer
the yellow wire on my sony is melting and blows fuses. if I let it cool down it works fine then... (More)
Answer
QX2-1440 Power Protect LED stuck on
Answer
I have a lanzar 2400 watt max pro st MXA 252 that blew out for no apparent reason. I definitely did... (More)
Describe your Car Amplifiers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Car Amplifier Experts
Top Audio & Video Equipment Repairmen
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
