Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Whirlpool adp 2966 f4 problem
By annieonline on Dec 03, 2007
my dishwasher has been flashing f4 for a while and not really cleaning my dishes. i found out that f4 meant that there was a blockage, so i pulled out the machine and the outlet pipe was kinked up , so i straightened it and i put the machine on, it sort of worked- it heated up the water ( which i think it hadn't been doing) and it went through most of the cycle before it flashed f4 again. i think everything had been washed not rinsed. now it just flashes f4 all the time.
foolishly, i decided to put a straightened out coathanger down the outlet tube to see if there was a blockage there. unfortunately the coathanger is now stuck . is it possible to take the waste outlet tube out of the machine to get the coathanger out?
i would really appreciate any help you could give me. thank you very much
Comments:
Dec 04, 2007
- Thank you for the answer. I am not very good technically , is this an easy job or should i get someone who knows what they are doing? How do you remove the right hand side panel? Do i need a special screwdriver? should i get a new hose as well?
Dec 04, 2007
- Thank you for your help , i will get someone to fix it
Best Solution
posted on Dec 04, 2007
Helpful)
COXY
Rank: Guru
Rating: 88%, 84 votes
I think on those you can gain acces to the outlet hose through removing the right hand side panel, if you do this I would advise changing your pump that the hose connects to ad this is probably whats causing the f4.
Comments:
Dec 04, 2007
- I think you best get someone to look at it, its not an easy job, a local engineer would probably charge around 60-70 gbp to supply and fit a new pump.
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
we are about to buy new dishdrawer lookin fisher and paykel
Answer
washing result has decreased drasticly. Detergent didn't even desolve completly. Inside of... (More)
Answer
White circular insert that fits below the lower rinse arms is broken. The part is white plastic,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dishwashers:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
