Question about Iomega 33089 250 GB Hard Drive
Iomega Firewire Hard Drive
My hard drive is making a churning noise. We have two in the office, which get changed once in a while, both make this noise. Can you help, when I change them over is there a program that I have to go into to get it running.
  • Anonymous Dec 24, 2007
    iomega hdd extern
    Problem Solver:
  • 15 Answers
There is an arm in a harddisk that holds the read-write heads. This arm can move the heads to tracks near the hub or near the edge of the disk. A normal hard disk is 5 inches (12.5 cm) or so in diameter. This arm, therefore, can move about 2 inches (5 cm) across the face of the disk. The speed at which this arm can move is astonishing. The arm is very light, and its actuator is powerful and precise. The arm can slide across the face of the disk hundreds of times per second if it needs to.
As the hard-disk arm moves back and forth rapidly, it sets up vibrations that our ears hear as sounds.
Posted on Dec 04, 2007
My wife and I bought an Apple mac computer just over 3 years ago, and as we wanted to store our large collection of CDs on i-Tunes on an external hard-drive and not on the Mac computer drive, we bought an...
no --there are no engineers at fixya site
from your description the aux hard drive has failed
Most hard drives using discs are good for around 3 years max and then the bushes and bearings fail
If that is the case then you will have to find a repair shop that has the capability to remove the disc from the hard drive and recover all that you have saved
if it as what I have suggested then consider this
There are hard drives (SSHD) on the market that use solid state technology and do not have spinning discs that fail over time
The cost is around $60.00 per gig of storage
best if you take it to a computer repair shop for a proper diagnosis and while there discuss the SSHD technology to prevent failures in future
Feb 27, 2017 | Iomega ULTRAMAX 1TB TRIPLE INTERFACE...
I need one user manual for iomega 250GB prestige USB 2.0 portable hard drive. Thanks. Sincerely J. Cervantes.
Portable Hard Drive USB 2.0/FireWire (Silver Series USB/FireWire)
User's Manual: View Online [HTML] - http://www.iomega.com/support/manuals/hdd2007/webhd07oct/en/consolidated/main.html#portdual
Download users's manual [717KB zipped HTML] - http://download.iomega.com/english/manuals/english/webhd-userman-en.zip
Quick Start Guide [PDF 943KB] - http://download.iomega.com/qsg/portable-usb-fw_euqi.pdf
Specifications - https://iomega-na-en.custhelp.com/app/answers/detail/a_id/18648/session/L2F2LzEvdGltZS8xMjkzMDc3NDkyL3NpZC9mNDUtY2Npaw%3D%3D
Oct 31, 2010 | Iomega 250GB USB2.0/FW 250 GB USB 2.0 Hard...
When I switch the drive on it 'ticks' but won't properly turn on for a long time — up to an hour. As I write this the drive has been ticking for over two hours and has still not booted up.
the clicking noise is the reader arm jumping across platters on your hard drive you have a dirty hard drive first clean all the dust from your computer specifically from around your hard drive using a high powered suction vacuum cleaner or a fine air blower from a air compressor making sure there is no moisture in the air lines then give the hard drive a firm tap on the side to free it up
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
hope this helps good luck
Sep 14, 2010 | Iomega ULTRAMAX 1TB TRIPLE INTERFACE...
Trying to find manuals how to use the iomega with my apple mac but are not sure which one i have. On the hard-drive it says iomega with an i above it.
Manuals are not the easiest to come by for Iomega hard drives, but I can certainly assist you with formatting your hard drive for your Mac
All you need to do is this:
font.f1 {font: 14.0px Times}  * From your desktop click anywhere on a blank space on your desktop.
*Now you should see Finder listed near the Apple menu icon.
* From the Finder menu, click on Go, then Utilities from the drop-down menu. This will take you to your Utilities folder.
* Locate and launch the Disk Utility application
* Once Disk Utility is open, with your Iomega drive hooked up to your Mac and turned on, look in the left side bar and you should see your hard drive.
* Click on the hard drive and this will make the right window available to you.
* Now click the Partition tab
* It is here that can change your volume scheme from Current to 1 partition (or more).
* Once you have done that make sure to give your hard drive a name.
* Under Format: Make sure to select "Mac OS Extended(Journaled) format (this is the readable format for a hard drive being used on Macs).
* Once you are satisfied that the partition(s) is configured to your liking, the click Options button.
* Select GUID Partition Table for Bootability on an Intel Mac computer or notebook
*or select Apple Partition Map for a Power PC based Mac computer or notebook.
• Click Ok for that selection
• Click the Partition button and your drive will be ready to use once the format completes.
This should do the trick. Let me know if it works for you.
Thanks!
-Mactechtrainer
Jan 20, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Ticking noise
Ticking noises are indicative of major hardware failures. As no HDD manufacturer actually warranties data, if you have important files on it your drive, you will likely need the help of a pro.
If you have all your data backed up elsewhere(including on the Mac), contact Iomega and have it replaced under warranty.
https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/cci/product.php
If you do need files recovered, let me know as well as your region and I will recommend a good location.
Chris
May 22, 2009 | Iomega ULTRAMAX 1TB TRIPLE INTERFACE...
IOMEGA eGo portable hard drive won't copy files from mac
Format your hardrive for Mac OS:
Go to Disk Utilities under the go menu in your finder. Select the external drive and click on the erase tab. Clikc erase again and it formats the drive. You can now copy files onto the drive.
Oct 29, 2008 | Iomega (33090) 250 GB Hard Drive
Can't instal external hard drive
Huh, try going on iomega;s webpage and download the driver off the site, it may be more rescent than the one in the box. Plus, are you running vista?
Oct 07, 2007 | Iomega Portable USB 2.0 & FireWire 400...
Iomega 33089 250 GB Hard Drive Logo
115 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Marvin
Marvin
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
