Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Bar does not run... Has power/suction?
The rotating bar does not run, however there is power and suction. Is there a reset button, etc?
Thanks,
George
  • 1 more comment
  • yamma Dec 08, 2007
    I have a new Dyson 18 slim and the brushes do not rotate. There appears to be a button to push but, when I do,nothing happens. Same as above, I have suction . I've tried to call the customer service number on my vacuum but I never seem to catch them in. The manual is usless.
    Mary Lou
  • Anonymous Dec 19, 2007
    the bar does not run although the belt is still connected and there is still suction
  • shubie Jan 09, 2008
    There is power and suction, but the bar does not move.
We had this same problem with our Dyson animal. We found that the bar had come off track, though it still appeared to be in proper place. By disassembling the thing, we cleaned it up and restet the bar and voila, it ran as good as new. We discovered that the bar does occasionally just become jarred loose, and now we know that whenever it stops rotating, we have a simple enough fix.
Posted on Dec 29, 2007
  • 372 Answers
Hi.
Check control knob on front left side is in drive or (D) when vacuuming carpet.
http://dc07.atspace.com/
Chris..
Posted on Dec 23, 2007
SOURCE:
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
Where is the reset button on dyson dc25?
I could be a switch, belt, brush bar motor or a wiring problem.
Jun 19, 2014 | Dyson DC25 Animal Bagless Upright Vacuum
Self Propel wheels not enough power to move machine over carpet.
Sounds like the transmission might need an overhaul. Take it to a local vacuum repair shop and have them look at the transmission.
Sep 03, 2009 | Vacuums
Power head not working
There is a gray button next to the red "power on" button that powers the brush unit. If the unit has tripped the reset for some reason it must be reset. This can be done by holding the gray button down for ten seconds while the unit is not running. When you power it up after this reset, the brush unit should run.
Jun 04, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
There is suction but no rotation of beater bar
replace the drive belt.
turn the vacuum over. take the buttom plate off, you can access the roller (beater). there should be a belt attached to the roller and the motor shaft.
Apr 14, 2009 | Vacuums
Beater bar has stopped turning
All beater and rotating brush bars are fairly easy to get to with a couple of screw on the bottom of your wan. They are driven by a belt and these belts come off, break, or the bar itself is stuck with rug material. Unplug your vacumn and get our screwdriver. It;s easy to figure out once inside the wan.
Mar 02, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Vacuum turns on and suction in hose works, beater bar won't turn
If you hear the motor in the head running and the beater bar isn't rotating, you probably need a drive belt. With the power off, make sure you can rotate the beater bar freely by hand, if it isn't bound up.. then locate and remove the baseplate screws to gain access to the beater bar itself, you'll see a drive belt pulley system and chances are, a broken belt. Replace it with a new one by pulling the beater bar assembly out of the housing and plcing the belt onto the motor shaft pulley as well as the beater bar pulley.. nest the beater bar back into the holder and reinstall the cover. Hope that helps !
Aug 14, 2008 | Eureka Vacuums
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
202 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
