Question about Sony CLIE PEG-NX73V Handheld
Clie control buttons
Function buttons at base of screen not operating (date Address etc) but keyboard buttons are. Why?
0 characters
1 Points
I have not used my clie for a VERY long time. I
The manual is available here on Fixya for your handheld. I'm including a link to the page that discusses the on-screen keyboard, but once there you can flip back and forth through the rest of the manual at need. Hope it helps!
Oct 01, 2009 | Sony CLIE PEG-SJ22 Handheld
Just fully charged Sony Clie'---backlight is too dim..How to adjust??
You can set your pen drag function to adjust the brightness.
Click the drop down menu on the top right of your screen, then click "system", then "prefs", then click the button at the bottom of the screen that says "pen". Next, click the drop down menu beside the little icon that looks like your clie. Click that and select "brightness". Now, when you drag your stylus from the bottom to the top of the screen, a little slider bar will appear to adjust the brightness.
Sep 14, 2009 | Sony CLIE PEG-UX50 Handheld
Multimedia system error
You can perform full reset after backup your data. Full reset or Hard reset can be done by holding reset and power button together and releasing it after 10 seconds. It will come up with confirmation to erase all data to set it to factory default. Once you choose "Yes" it will be out of box state. It might fix the issue. For Memory card data loss you can use your PC to retrieve back by using application such as Active Undelete which can be found at
Good Luck
Mar 15, 2009 | Sony CLIE PEG-TH55 Handheld
How do I CLEAR everything on my Clie
Hard Reset CLIE Sony Series
  1. Connect the CLIE handheld using the AC adapter and take out the stylus pin by twisting the upper part of the stylus.
  2. Push down and hold the power button of the unit and use the stylus to slowly press and release the reset button on the back.
  3. When the Palm screen will appear release the power button.
  4. At the “Erase all data?” prompt, push the upper part of the scroll button on the front of the device to confirm OK. The Sony pda is now reset and you have only to follow the SetUp steps as prompted.
Feb 01, 2009 | Sony CLIE PEG-SJ22 Handheld
I'm in the process of changing from SJ22 to Smartphone running Windows Mobile 6.1 and I have found a way round this by sending data as vcard to myself in outlook then opening the attachment and saving and closing - this is then sent to your device on the next sync. It is a bit long winded but it works.
Open Outlook and leave it open.
In Palm, select the address you want to send, then in EDIT menu choose Forward as vcard, send and close the outlook pop up, saving changes.
Go to Outlook Inbox and open the attachment then save and close.
Aug 11, 2008 | Sony CLIE PEG-SJ22 Handheld
Vista will not recognize my Clie
Please install thePalm Desktop Operating System 6.0 or higher from any search engine or Palmzone.
This will resolve the issue.
Chris 2030
Jan 12, 2008 | Sony CLIE PEG-T615C Handheld
Installation disk
Post an email address here and I'll send you a zip of the original install disk.
Jan 10, 2008 | Sony CLIE PEG-TJ37 Handheld
Clie PEG-SJ22 does not charge battery
Have you tried resetting the unit? There's a little button on the back that you can press in with a paper clip. That'll cause the unit to reset (you won't lose data) and then you might be good for charging.
Dec 16, 2007 | Sony CLIE PEG-SJ22 Handheld
Sony Clie PEG-T615C Hotsync doesn't work with my Windows Vista Home Edition
I must maintain my older XP system just to maintain my pda. Awkward, for sure. I have not contacted Sony yet.
I once discarded a very nice, functioning rinter by Canon because there was no driver for XP.
Dec 12, 2007 | Sony CLIE PEG-T615C Handheld
Sony Clie PEG-NX80 Camera
difficult to say, on some tis the mylar printed circuit cable goes bad. on some its the ccd imager, best thing to do would be to buy a new camera module for it and install, not a difficult procedure. but involved and the device is very static sensitive, so you should have full esd pro and a true earth ground. i can do this repair myself as i operate an ebay based pda refurb. tpsceo@gmail if youre interested, i might be able to scare up a camera module to sell, have to check my inventory....
Nov 22, 2007 | Sony CLIE PEG-NX80V Handheld
Sony CLIE PEG-NX73V Handheld Logo
18 people viewed this question
Top Sony PDAs Experts
Lawrence Oravetz
Are you a Sony PDA Expert? Answer questions, earn points and help others
