Hoover Elite U5061-900 Bagged Upright Vacuum
Problem for Hoover Elite U5061-900 Bagged Upright Vacuum
Putting the belt over the motor shaft
By doctorbluesk on Aug 22, 2009
"Pull the belt through the hole and put it over the motor spindle. Careful to make sure there is no twist in the belt. This can be difficult as there is plenty of tension on belt".
easy to say, hard to do.
i have worked, trying to install the belt over the motor shaft. i have spent hours. it is nigh unto impossible. it would be nice to have it "user-friendly". i have had to take it to a vacuum shop to have this done. i am trytng, yet again to install the replacement belt. (why do they break so often?). my unit gets minimal use. i must continually replace my belts. trying to stretch the belt over the motor shaft is excruciating.
Solution #1
posted on Aug 22, 2009
Not Rated)
lorlaman
Rank: Guru
Rating: 90%, 10 votes
The belt may be overloaded because something it is driving is jammed or partially siezed . It could be a bad bearing or string wrapped around the beater brush etc. Check that everything moves really freely before going through this again. Take it all apart and clean it good. Don't get any oil on the belt or pulleys, but make sure the bearings on anything thta turns is clear and lubricated.
Was this helpful?
Yes
No
Popular Solutions for Hoover Elite U5061-900 Bagged
Questions and Unsolved Problems for Hoover Elite U5061-900 Bagged
Do you recommend Hoover Elite U5061-900 Bagged Upright Vacuum?
Answer
Answer
Bottom bearing rumbble on Hoover Brush n wash F5857001
Answer
I just recently purchase a Hoover carpet Cleaner. I used it twice AND NOW IT DOES NOT EXTRACT THE... (More)
Answer
water will not disperse smell rubber burning new machine used only one time
Answer
Hoover turbo power 1500 have part of bottom off to replace belt but can't find where to attach it?... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hoover Elite U5061-900 Bagged...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1220
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
