Distorted sound I have a Space brand LCD TV & when a movie comes on with heavy bass sound. it becomes very distorted as if it is vibrating. Not a good listen. 80% of the time it's fine but just some movies & some adds. I am not able to adjust sound on the TV to fix problem
  • hornet72 Dec 13, 2007
    I've got the same problem, above about 20 on the volume scale there is a distortion and buzz on the bass coming through the speakers. I t doesn't go away even when the bass it set at the lowest level.
I have 37 inch polaroid that is less than a year old
that when you turn it on the sound distorted?
Posted on Jan 18, 2008
    President:
  • 4,402 Answers
Sounds like you have a bad speaker or where the mounts for the speaker are broke.
Posted on Dec 03, 2007
SOURCE:
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
The sub woofer had a distorted sound.
the distorted sound coming out of your sub-w is actually originating from your audio unit, Have your audio unit check for possible repair
Oct 31, 2015 | Audio Players & Recorders
Popping noise and now the sound is distorted. its like a static and vibration coming from the speakers. why is this happening? how do i fix it?
Hello
The audio output section of your TV has damaged. The set need a through checkup, before replacing this board; especially to the voltage input to it, from the power supply board need special care.
Feb 12, 2012 | Magnavox 40MF430B LCD TV
My SONY Home Theater Model HT-6600DP unit was working fine and then about tow years after...present, my sub woofer is sounding distorted. Why is this happening? Please help me as I often watch my home...
Is it so even at lower volumes?
Are you sure it's the sub distorting and not the front or center speakers?
If you designate them incorrectly as Large (which tells the receiver they CAN effectively produce bass frequencies) they will probably distort in the presence of low frequencies.
See Page 17, 19
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-HT-6600DP-Home-Theater-Systems-manual/id/390ag319/t/2/
Mar 13, 2011 | Sony HT-6600DP System
I have a brand new LG 37" television. Picture quality is perfect but the in-built speakers vibrate heavily to a deep bass sound. I played "Close Encounters of the 3rd Kind" through the dvd player and in...
i also have this tv.same problem too.i bought two multimedia bose speakers for 100$. they are actually designed for a laptop but trust me....they are better than most so called surround sound speakers designed for tv's.these tv's are not known for their built in speakers.
Aug 17, 2010 | LG 37LG50 37 in. LCD HDTV
I have a vizio vo42l hdtv - the sound and picture mess up
try a new antenna or a signal booster..this will help.. and make sure you have a digital antenna. also try to re-scan the tv because while you scaned it first something was probably not right...hope this helps
Sep 04, 2009 | Vizio GV42L 42 in. LCD Television
Distorted / skipping sounds from Acer laptop
Go to the sound icon which is at the right hand bottom corner on your task bar, explore properties cheack wheather voice supression is any thing else than 0.As well as check for enviroment.
Mar 14, 2009 | Acer Aspire 5100 Notebook
LG flat screen TV speakers make a vibrating noise
I have this problem with my 37LG30.
They all seem to have the same factory flaw.
The plastic bezel and rear is vibrating against itself I have found.
Tonight, just now, I just took all the front bezel screws out,(from the back) loosened the other 4 big screws in the rear center(I don't recommend removing them)and loosened the stand screws also and tried separating the bezel from the back as I went around the set. This did not really help much except around the bottom where the noise/vibrating comes from-the speaker area.
The two plastic pieces are vibrating against one another.
The vibrating was coming from the speaker area without doubt.
The next thing was to try separating at the bottom where the speakers are with my fingers and a stiff metal nail file carefully..fingers seemed to work best for me.
As I separated the front bezel from the rear housing (at the speaker location)most if not all the buzzing/vibrating /distortion went away.
I then inserted small pieces of cotton (you can use felt, or similar I suppose) and buttoned it all back up;put the screws in
Almost all the distortion and speaker buzz/vibratingis gone except on very low frequencies.
good luck!
Jan 29, 2009 | LG 42LC2D 42 in. LCD HDTV
Problems with sound that buzz/vibration sound My brand new Toshiba 40 LCD has similar occasional buzz/ vibration coming from inside TV
Same problem with my new Toshiba 55" LCD.
Also, after being on for awhile, the sound suddenly gets distorted in a fuzzy, echoie kind of way. Switching to a non-digital channel and switching back seems to make that correct itself. I may try a new HDMI cable to see if the problem goes away. Any other ideas?
Jan 14, 2009 | Televison & Video
Televison & Video Logo
381 people viewed this question
Top Televison & Video Experts
Ekse
