Flat Panel Televisions
Problem for Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Digital Visio 42" LCD TV stopped rec...
By justin62 on Aug 22, 2009
Digital LCD TV stopped receiving digital TV signal. Channel changing function not responding on remote nor tv. Able to change channel by punching numbers only.
Checked power to the antenna. Antenna functions fine. Went to settings and did a search for signal. Got some analog signals. TV won't even try to search for digital; progress bar stays at zero.
When accessing a Digital channel, I see solid blue. When accessing Analog channel, I can see it or it is fuzzy.
Thanks
Solution #1
posted on Aug 22, 2009
Somewhat Helpful)
j4bs
Rank: Master
Rating: 88%, 14 votes
Check all your connections in the back, if they're all good replace the main board in the tv.
Was this helpful?
Yes
No
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
I'm looking to purchase a 50 inch plasma tv, and I want a recommendation on which one to buy. Thank... (More)
Answer
Have a Toshiba 42h83 that has a blue and yellow "shadow", any suggestions?
Answer
So my Samsung flatscreen has steadily been ''popping'' for a month or two and each time, it takes... (More)
Answer
my tv is a viore 48'' the problem you turn the tv on and couple seconds latter it shup off..
Answer
Akira IPT-421XH wont turn on, i can see a green ligth and that's it, what can i do to make turn... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
