Water level drops during wash/rinse cycle
When I use the super water level on the machine, the water level drops during the wash/rinse cycle causing the machine to stop washing and refill back to the super level. I find that the problem only occurs with the super water level. I am not sure what causes the problem I have checked the drain hose that drains directly into the drain pipe. The water is leaking out the machine somehow causing the machine to get below the water level and cause it to refill again.
    President:
  • 1,294 Answers
Check the exit hose behind, it should be at least 3 feet from ground level, and not too deep into the wall stand-pipe. You will find a level mark behind the machine......check this out.
Your pump pumps this water OVER this height.
Posted on Dec 03, 2007
What are causes for low water level in my dishwasher? It cancels the cycle by itself with error code 6-1
You may have a faulty water level switch which is shutting off the water sooner than it should. it may also be a faulty pc board
Feb 11, 2015 | Kenmore Washing Machines
I bought a brand new Hotpoint washer, model #HSWP1000M3WW. The water level for super size load during wash seems high enough. But the water level for the rinse is about a third of the super wash level. ...
I would check with the vendor that sold you the unit and see what they have to say or send an email to the Contact Us link on their website and ask. I am guessing no mention of the in your owners manual?
Dec 03, 2014 | Washing Machines
Water runs out of soap box during rinse cycle
Hi there, given this a lot of thought. I had same problem. Could be that you are in a hard water area. Soap is not dissolving properly and building up in the rubber tube between soap box and drum. How I resolved this. Turn off power remove top cover of washing machine and massage the rubber pipe between soap box and drum to soften and cause undissolved saoa to drop into drum. This should rectify problem. Also consider using every month some descaler powder called Descaler cheapest from Axxxxn best wishes.
Feb 26, 2014 | Amana Tandem 7300 Washer and Dryer Stack...
After working well for six months, my washer now expels water at random points during the wash and rinse cycles.
Check inside the fill hose for debris. There is a screen designed to block debris from getting inside the machine valve. If the screen builds up with debris the water slows down. Sounds like the water is filling too slow. Also the unit and/or the load may not be balanced causing it to stop and drain out. If it's okay then see what lights are blinking when these events occur and post here.
Jun 06, 2013 | Haier HLP21E Top Load Washer
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
Apr 21, 2010 | Electrolux EIFLW55HIW Front Load Washer...
My Maytag top load, looks like PAV2300 but not sure, will not rinse. The water drizzles a bit during the cycle and I hear the timer but the machine does not rinse. I cannot force it into rinse. I have to...
Hi and welcome to FixYa. I am Kelly
There is a water level pressure switch inside the top panel that has 3 wires on it and a vacuum line. That pressure switch controls the water inlet valve functions via the timer.
If by chance the pressure sensing line is getting hydraulically locked with water due to some form of obstruction it can cause the symptom you describe.
This pressure switch also controls the start of the spin once the water level has dropped (prevents the wash tub from being a water brake and damaging the motor clutch)
If the water level pressure switch is working normally then the only thing left is the timer.
You can do your own testing of the water level presure switch with an external vacuum hose (3 feet in length) connected in place of the machine hose. (DO NOT drop the machine hose when you disconnect it!)
1. place timer on wash and start filling. LID CLOSED
a. Force air orally into the external line
1) Result fill stops agitation begins
2. place timer in spin LID CLOSED and force air into external line until the pressure switch clicks.
a. START SPIN CYCLE NOW and listen for water pump out
b. release pressure on external air line
1) result tub starts spinning
If it passes the above tests your looking at a timer problem causing your no rinse situation.
Thanks for using FixYa!
Kelly
Feb 18, 2010 | Maytag PAV2300 Top Load Washer
LG Tromm WM2277HW Water level to low
this is normal the pic are all photo shop water you clothes are clean right?
Feb 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
Jan 27, 2009 | Kenmore 22422 Top Load Washer
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
217 people viewed this question
Top Washing Machines Experts
