Question about Microsoft SQL Server Standard Edition for PC
MyEclipse6.0.1 connection with sqlserver 2000
I have connect SQL Server 2000 with MyEclipse 6.0.1 but some Error arrived Like
[error while performing login with sqlserver driver sqlserver 2000 driver for jdbc]Error Establising Socket
Please give me full configuration:
Hi
Try with MS SqlServer 2005 JDBC Driver,
i had a similar problem with 2000 jdbc driver
Posted on Dec 04, 2007
Creating a new database using an MDF file
An MDF file isn't a backup file isn't the main data file (or master data file depending on who you ask) hence the file extension MDF. You can attach the MDF to the database by right clicking on the databases folder in Enterprise Manager (SQL 2000) or Management Studio (SQL 2005) then selecting all tasks and then Attach Database.
When you do this you will get an error about the log file missing. This shouldn't matter as SQL Server will simply create a new log file for you.
This will only work if the SQL Server was stopped when you copied the MDF file from the old SQL Server. If you copied the file while the SQL Server was running this file probably will not attach either and you will need to get a valid backup of the database.
Download help tool for sql database - SQL Server Restore Toolbox.
http://www.sqlserver.restoretools.com/
You can read up more on SQL Server here.
http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/498-creating-a-new-database-using-an-mdf-file?_=1416149856104/
Nov 16, 2014 | Microsoft SQL Server 2000 Standard Edition...
How to recover deleted Microsoft SQL server MDF files?
Recover and repair MDF files with simple and efficetive tool to repair and recover MDF files from corrupt and damaged SQL server, which tool support all king of SQL server version and Windows OS. Visit here: http://www.en.mdfrepair.net
Read blog post: http://exchangerecovery.hubpages.com/hub/How-to-perform-SQL-Database-Recovery Corrupt MDF File Repair Utility
Apr 17, 2014 | Computers & Internet
Network error IOException: Connection refused: connect
Please check that you are on the same sub net and that your network setting correspond to those required by the server including matching access passwords etc.
Aug 19, 2009 | Microsoft SQL Server 2000 Standard Edition...
Restore problem on brightstor
the registry key SQLprotocol made brightstor use named pipes to restore which is not supported in SQL 2005.
Jan 14, 2009 | Computer Associates BrightStor ARCserve...
I can't connect the ms-sql database with flex
It sounds like you don't have the proper authentication to access the SQL server from the error code you are receiving. I would ask you SQL DBA to check on the permissions within SQL and verify that you have the proper access rights to the database you are connecting too. It is SQL throwing that exception error...
Cheers!
J the Guru
Jun 27, 2017 | Microsoft SQL Server 2000 Standard Edition...
SQL Server does not exist or access denied
check your firewall or the sql server machine firewall.
Jan 06, 2009 | Microsoft SQL Server 2005 Standard Edition
Java.sql.SQLException: Network error IOException: Connection refused: connect
I too was facing the same problem as mentioned by you and couldn't connect through telnet localhost 1433.
Solution : Just go to SQL server configuration manager----SQL Server Network configuration----Protocols for SQLEXPRESS and in that right click on TCP/IP and in properties field make all TCP/IP port to 1433 which is blank. Start and Restart the SQL server and you can telnet localhost 1433 and it works. Hope this will help.
Ghanshyam
gimatpune@hotmail.com
Aug 07, 2008 | Microsoft SQL Server 2000 Standard Edition...
Error while trying to login to database - Error establishing sokcet.
this page says you need service pack 3:
http://www.myeclipseide.com/PNphpBB2+file-viewtopic-t-7813.html
and here is Microsoft's information
http://support.microsoft.com/kb/313178
Jan 03, 2008 | Microsoft SQL Server Standard Edition for...
You have a named instance installed with dynamic ports configured (default) named "local". In this case, the connection string would be localhost\local instead of local:1433. You could alternatively configure the service to use a fixed port and then connect using just localhost:. With dynamic ports, you would have to resolve the name of the service through SqlBrowser, which should be running
Nov 03, 2017 | Microsoft SQL Server Standard Edition for...
Microsoft SQL Server Standard Edition for PC Logo
158 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
