Question about Maytag Washing Machines
WHAT IS THE TUB CAPACITY OF MY MAYTAG MAV6000AWW WASHER?
SOURCE:
SOURCE: Quit Working
it would be the switch get a knife and swip at both ends off ware the top lid section meets front side[join at front]this will allow top section to lift up switch may be broken or to short to turn on if to stort drill hole & pot screw in to adjust lenght of swich leaver
Posted on Dec 24, 2007
SOURCE: maytag washer capacity
did you find your answer?
Posted on Sep 13, 2008
  • 219 Answers
SOURCE: Maytag MAV6000AWW washer will not run thru cycles consistently
yes it would be the timer but they also stop if it gets off balance if its just off balance u should be able to lift the lid rearrange then start it again if that doesnt work it is the timer
Posted on May 21, 2009
  • 411 Answers
SOURCE: Maytag MAV6000AWW does not come on. Electrical
It's probably not the motor.
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you
go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Dec 04, 2009
heatman101
  • 43501 Answers
SOURCE: the tub in my maytag washer will not turn so my
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 28, 2010
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Tub capacity of maytag performa
It holds 3.9 cu feet. According to Maytag "This 3.9 cu. ft. capacity high-efficiency washer also features the MaxExtractâ„¢ option, which spins clothes at up to 1,300 RPM and means less time doing laundry. You get all that and still use 79 percent less water and 76 percent less energy". A cubic foot is the volume of a cube whose sides are all 1 foot long.
Feb 13, 2015 | Maytag Performa LAT2500A
Maytag oversize capacity washer just finished filling up the tub with water. Then it had a burning rubber smell. I shut it off and on a bunch of times and there isn't even any sound. (like the mot
You need to observe and check after disconnecting the power , touch the motor, the element area or the control panel or the valves/pump.
If you notice any heat on these , it can be the culprit.
You can proceed to remove the suspected part to discover what was the reason for the burning rubber smell.
Click this link: Element
Jan 25, 2013 | Maytag 3.3 cu. ft. Oversize Capacity Plus...
May 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag neptune mah3000aww tub size
The answer is:
CAPACITY 3.1 Cubic Feet
The reference for this answer can be found here:
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Seach in this document for "capacity".
SECTION 1. GENERAL INFORMATION Page 1-4
Nov 20, 2008 | Maytag Neptune Washer
Quit Working
Dec 12, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag MAV6000Aww washer-loud noise when spinning
Chances are it is not the tub. It is probably the transmission. It has been my experience that the transmission bearing starts to make noise. Look under the unit to see if you can spot any transmission oil. If there is oil, it's time to start shopping for a new unit.
Sep 26, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
50 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
