Question about Nokia N70 Cellular Phone
N70 Call Logs
I have resently cleared by call log (received, missed and dialled numbers). But now the the call log is not registering the incomming calls, or dialed numbers or missed calls. Do you have any suggestions
  • 1 more comment
  • Anonymous Mar 26, 2008
    I tried to reset my phone using the code *#7780#, but now I need a lock code?
  • Anonymous Mar 19, 2014
    dialled, received or missed calls appear as time eg 00:00. and there is an icon beside the network bar looks like a bed.
  • Anonymous Mar 30, 2014
    recovery of dialled and received calls and sent and received messages
  • 175 Answers
Just reset the phone it might solve your problem.
here's the code to reset *#7780#
peace!
Posted on Dec 03, 2007
SOURCE:
Hi,i have nokia 5800 xpress music unable to view dialed ,received & missed calls. It says no dialed numbers
  • Increase the log duration option.
  • Also check whether the theme is blocking you from viewing the call logs.
Mar 19, 2013 | Nokia XpressMusic 5800
Nokia C6-01 How do I delete single dialled or received calls from the Log? I can delete from the dialled screen but the call remains in the Log.
Hello Sinyoro,
In the Call Log eg. Dialed Numbers, highlight the number/contact you want to delete, press "Option" and then select "Delete", this will delete only the selected entry. Make sure you don't press the "Delete All".
Hope this helps.
Thanks.
Jan 01, 2018 | Cell Phones
HOW DO YOU CLEAR RECENT CALL AND MESSAGES
Hi trsampson,
To clear recent calls, here are the steps to follow:
1. Go to the 'Menu' option.
2. Scroll, till you get to call register.
3. Select it, then scroll to 'delete recent call list'.
4. After you have selected it, you would be provided with the options to delete,
i. 'All calls', selecting it would entirely wipe off your entire call log.
ii. 'Missed call', selecting it would delete your entire missed call on the call log.
iii. 'Received calls', selecting this deletes all your received calls.
iv. 'Dialled calls', selecting this deletes all your dialled calls on d log.
You could also perform selective deleting. You might want to delete a/some paticular number(s) that is on the log, not the entire log.
To effect this, after step 2 above, you can scroll to either of 'missed calls', 'received calls', or 'dialled calls'. Select the one which pertains to the number you want to delete, scroll through till you get to the particular number(s), select 'options', scroll till you get to 'delete', then select delete, and the number is deleted. Do it for as many numbers as you want to be deleted.
To clear messages,
1. Select the menu option, scroll till you get to 'messages'.
2. Select 'messages', scroll for either 'inbox' or 'sent messages'.
3. Select whichever you want to delete from, scroll to the particular message, and select 'options', sroll again, and select 'delete'.
Hope that helped?
Success.
May 09, 2011 | Motorola Cell Phones
How do i delete my call log on a nokia x3-o2 phone
To delete the call log of Your nokia x3-o2 is very simple, all You need to do is follow the steps below:
  1. Go to the menu,
  2. select the call log from the menu,
  3. From the call log, You have call log, missed call, received calls, dialled numbers, and others,
  4. From the list You have "clear call log", select it
  5. A option will will come up asking what You want to clear, just select call log,
  6. It will instantly delete all call log.
Hope this helped. Thank You for using FixYa!!!
Jan 21, 2011 | Nokia X3 Cell Phone
I have nokia N70 do not showing call recd, dialled and missed details though log setting are perfectly okay
Have you restarted your phone? If not try it. Restoring the phone settings to "Factory Default" is also helpful. This happens when you never clear the log files. Good luck. Thanks for using FixYa.
Jun 11, 2010 | Nokia N70 Cellular Phone
How to do check my missed call log
A Panasonic TDx system has 2 types of call logs, one personal for the set, and one for the ICD group.
Pick a spare button, press PROG, the button, and dial 54 STORE.
If you had incoming: 00x on your display, that button will light and you can now press it to see who called. Your Navigator UP/DONW key will step you forward or backward through the log. The LEFT/RIGHT key will display the 4 lines of the display if you're not using a 7636 phone.
If you want to see incoming calls to a particular ICD group, pick another button, and dial 54 plus the ICD group number. For example, I used 100 as my ICD group (now 600 by default). I have 2 buttons, one logs my extension calls, one displays the system calls.
Carl
Mar 09, 2009 | Panasonic KX-T7630 Corded Phone
No log for calls
The log remembers call lengths and all transferred data, but only if you start the log application from the main menu. It does not work if the log is entered by clicking the green button while in stand-by mode. When entered from the main menu the log lets you go into an even more detailed log, which contains info about all the operations with the phone: individual calls and data transfers.
Also if you want to transfer call logs to your phone, may be you can use 3rd party software,
http://tinyhack.com/freewarelist/s603rd/2007/03/02/logexport/
Transfer the .sis file to your phone and open it with filemanager.
else if u want directly save stuff online on ur personal account use www.wavesecure.com
Hopefully this was helpful
Jun 11, 2008 | Nokia N70 Cellular Phone
MOTO KRZR
in recent calls press up arrow key quickly followed by * Each time you do this you will cycle through, missed calls, received calls, dialled calls, then back to recent calls.
Sep 06, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
My nokia 6600 can`t register lod details
format the phone memory.the code is *#7370#.Be care you gona louse all your data.
Jul 11, 2007 | Nokia 6600
Nokia N70 Cellular Phone Logo
351 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
