Question about Epson Stylus Photo R200 InkJet Printer
Black ink Hi I have been printing fine with the r200 but the black ink has suddenly stopped completely. I have cleaned the heads put in new cartages and still nothing. The other colures are fine!!! Just the black.
  • Anonymous Dec 09, 2007
    Same problem, just with the dark cyan cartridge...
  • Namuna Dec 21, 2007
    Same situation here. I've got the R200 as well. I'm using Generic brand stuff, but it's been working fine for me all this time (was working fine just a couple of days ago.
    Now it won't print black whatsoever, even after putting in a brand new black cartridge.
I had a similar problem with the r320 epson
I found that it had blocked.
this works well to clear the head
1 switch on the printer with the cover open
2 as the cartridge head moves away from its docked position pull the mains plug.
3it is then possible to slide the head to the left .
4 there is a square of flet on the right the head would normally be over, add a squirt of mr muscle bathroom cleaner on the pad ( main off)
5plug the printer back in and the head will return the the docked position.
6 leave for and hour or 6 then try to print
Posted on Feb 05, 2008
SOURCE:
Suddenly stopped printing all colors. Will only
Hi, it could be few things wich you having problem with.
First, how old are the ink tanks, it could be clodged.
Second the print head nozzles are clodged at that places.
Third, the purge unit does not work OK.
First remove all inks out and remove print head. Then on wet cloth, wet it with distiled water, few times press the bottom of print head ( nozzles ), then the 4 circles must change from colour to white. That means that nozzles are cleaned.
Dry head by pressing it on dry cloth.
Put it in, also the inks, and run few times the deep head cleaning. Every time take a look at print pattern.
If the head is to badlly clodged, test pattern would be just a little bit more better.
But now you know if the problem is in head or something else ( purge unit or inks ). The new head isnt so cheap regarding the printer so then the best solution would be to buy new printer.
If you do not want to buy laser colour printer, atleast buy one on wich ink tanks has printhead on. Its slightly costly, but you have one worry less - the print head is changed every time you change the ink.
Hope that helped
Jul 17, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
I CANNOT PRINT BLACK ON MY EPSON STYLUS PHOTO R200. All other colors print. I have replaced all the cartridges. This is my forth attempt at trying to contact you people. CAN YOU HELP ME?
this issue may have several causes:
1. make sure that you've removed the yellow ribbon from the top of the cartridge before installing it. it is there to keep the ink fresh before it's installed and has to be removed to enable the ink to flow into the print head. (not all epson cartridges have this ribbon though)
2. check all the settings in the printer driver or simply remove the current driver completely and reinstall the latest driver you can find on the epson site.
3. the black print head may be clogged. in this case, performing cleanings will help, possibly several cleanings are necessary
4. there may be a faulty connection between the printer's mainboard and the print head.
5.there may be an electronical problem with either the print head or the mainboard.
in the last two options it's better to let a professional technician look at it.
Mar 08, 2010 | Epson Stylus Photo R200 InkJet Printer
HP G85xi remove and check color cartridge message
Hi you can remove your Printer cartage and look see
ink points (dots) you can erase ink point and reattach your cartage your printer its Ready to use.
Jul 06, 2017 | HP OfficeJet G85 All-In-One InkJet Printer
Black ink jet doesn't print
if your black ink does not print, there is a possibility that the nozzle of your printer are clogged by dried inks, to print a nozzle check. turn off the printer then press and hold the paper (middle) and power buttons together for 3 seconds then release. it should feed the paper and print a nozzle check pattern. if the black lines are full of gaps or breaks in the line. you need to do head cleaning to remove the clogs, press and hold the ink button (teardrop) for 3 seconds, wait until the power (green )light stopped flashing. turn the printer off then print a nozzle check again. just repeat the head cleaning process until the black pattern is ok, as well as the other colors. all shld. be complete.
then print
Feb 11, 2010 | Epson Stylus Photo R200 InkJet Printer
Suddenly it wont priny black, have tried to replace with i new. Paper is offcourse removed, but it wont print black. Have run all cleaning programs. Could it be under the ink tank? How can i get to it?
Maybe you need new black ink cartage, or new color if its one pint cartage. follow the procedure under the bonet to change the ink cartages,. hope this helps
Nov 30, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
Suddenly stopped printing in black though colour is OK.I've tried all the usual things!
the ink head is probably jammed with dry ink. wihen the head is jammed, a lot of ink will pool at the bottom right of the printer. clean that pool, and dab the black ink head with a damp paper towel, but do not rub. blow the ink head with a can of compressed air. run a nozzle cleaning, and nozzle check until the printer is printing better. the nozzle check prints out grid for each color. if the grid is complete the printer is fine. sometimes a few horizontal bars will be missing and cannot be cleaned.
Nov 17, 2009 | HP Photosmart 2575 All-In-One InkJet...
The dont know how to switch the ink cartages
The large black ink cartridge is used for printing text and other general black printing. The small black cartridge is used when printing graphics and other fine details. Each cartridge feeds to a different part of the print head, which is used for different purposes.
May 27, 2009 | Canon PIXMA iP3600 Photo Printer
My Canon i860 just can't print out black words, it's frustrating
pull the ink cartage back out to see if a clear film is not on the cartage??? Check the area by cleaning the ink cartage with rubbing alchole, and also the area that the ink cartage goes into. Use a cotton ball the clean these area with.
Jan 31, 2009 | Canon i860 InkJet Photo Printer
Printer will not print black ink
Hi please try these steps:::
Right-click the printer icon, and then select 'Properties'.
2. Click the 'Maintenance' tab, and then click 'Deep Cleaning'.
3. Select 'All Colors', 'Black' or 'Color' for the print head to be cleaned.
4. Read the message displayed, and then click 'OK'. The power lamp blinks and print head deep cleaning starts. (Do not perform any other operations until print head deep cleaning is complete. Print head deep cleaning takes about 1 minute.)
IF ABOVE STEPS DOESN'T WORK TRY THESE STEPS BELOW
Check ink tank vent hole The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
  1. Confirm there is no orange tape across the top of the ink tank
  2. If the orange tape is as shown in Figure (1), it is properly removed.
    *BCI-3's shown in this example.
  3. If the orange tape is as shown in Figure (2), remove the remaining tape to the level shown in Figure (1).
  4. Make sure each ink tank is snapped into the printer.
    IF THESE STEPS DIDNOT WORK THEN YOUR PRINTER NEEDS REPAIR(You might need to change the printer head.)
Jun 09, 2008 | Canon i850 InkJet Photo Printer
Colors print, but not the black!
that same thing happen to me try to wipe the needle that the ink is on with baby wipes.
Nov 27, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Epson Stylus Photo R200 InkJet Printer Logo
88 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
