Question about LG Shine KE970 Cellular Phone
Reset my Call duration
To see how many minutes I have used
    Problem Solver:
  • 18 Answers
Go to setting check call duration of total calls and even u can check by out going and incoming calls
Posted on Dec 03, 2007
How to set digital part of the watch
[PDF]4 Button Digital Watch - Dakota Watch
https://www.dakotawatch.com/PDF_FILES/Digital.pdf
In normal time mode, Hold L2 for 2 seconds to alarm time set mode, then L2 again to normal time set mode, the second digits begin flashing. Press R2 to reset the seconds to "00", press R1 to switch to the minute digits. Press R2 to advance the minutes. Press R1 to switch to the hour digits.
how to set time in digital watch - YouTube
? 1:13
https://www.youtube.com/watch?v=4FmHYMeXbDA
Oct 26, 2011 - Uploaded by Vedant Sen
https://www.youtube.com/watch?v=u_H5I3H15R8 ... how to setyour digital watch {UPDATED} - Duration: 1:20. by Vedant Sen 3,424 views ... The 10 Greatest Wrist Watches of all Time REVISED FOR 2014 - Part 1 - Duration: ...
How To Change The Time On Most Digital Watches - YouTube
? 8:40
https://www.youtube.com/watch?v=kBvaePDtEUU
Jun 27, 2012 - Uploaded by Pitskate
How To Change The Time On Most Digital Watches. Pitskate ...How to change / set time on Armitron watch, 45/7004. - Duration: 2:02. by ...
Jan 05, 2016 | Watches
I need instructions of Melnor 304F timer for watering
From the Melnor 304f actual instructions:
Use 9V alkaline batter only! Flashing lighs indicate that the battery is low and needs to be replaced.
1) To start: Turn Dial to Off position and press ENTER
2) Set Time: set the current time and press ENTER
3) Start Time: set the time to start the first irrigation cycle and press ENTER.
4) Frequency: Set the frequency of the irrigation cycle e.g. twice a day = 12h and press entere.
5) Duration: Set the duration of the first irrigation cycle and press ENTER.
-- to change the duration
Turn the dial to the new duration and press ENTER
--to turn the water on manually
Turn dial to ON position.. The water will turn off automatically after 30 minutes.
-- to turn the water OFF
Turn the dial to the OFF position
Do NOT press ENTER when dial is in OFF position, otherwise the unit will clear the program, and you have to Reprogram the unit following the steps 2 through 5.
Jun 29, 2014 | Flotec Garden
Hi, I have a sony handycam hdr-cx160 with I bought a np-fv70 battery and my problem is that my camera turn off after I spend some time used it, Like 2 or 5 minutes. it is charged, the camera recognize the...
Hi luismasramir ,
Seems to be the case where the battery is not fully recharged , Please follow the below steps :-
  1. Please make sure that you charge your battery fully , till the time you see an indicator for the battery being fully charged , or may be you see an icon in the display screen with the charge status.
  2. As far the 6.30 hr duration that you have mentioned, this duration reflects the time that you have left for total recording space on your disk or memory card depending on your current source for recording.
  3. The above duration is not to be confused with the battery usage time.
Hope his helps ...:)
May 11, 2011 | Sony Handycam HDR-CX160 Camcorder
I cant see call duration while calling after enabling call durati
Try to reset the factory setting. It might be the software problem.
May 11, 2010 | Nokia N73 Cellular Phone
I have a strange problem with my computer. Each time I open 4-5 tabs on Internet Explorer 8, it freezes for a duration of 1 minute. Help...
You should be able to go to Tools->Internet Options->Advanced->Reset and reset the Internet Explorer. Please try and let me know if it works.
Dec 04, 2009 | HP Pavilion ze2000 Notebook
AUDIOCODES MP-118 FXO
Hi, I am using Audiocodes MP-118 FXO too
Man, check the Reverse Polarity.
1st.- Go to Protocol Management
2nd.-Go to Advance Parameter
3rd.- Go to General Parameter
4th.- Go to Enable Polarity Reversal and select ENABLE
5th.- BURN and RESET
You have FAS calls, because Reverse Polarity is disable.
Lucky
May 28, 2009 | AudioCodes MP118 Analog Modem
How to set kenneth cole unlisted digital watch with 4 buttons
OK I'll do my best to describe the procedure...
Part 1:
Press mode button till the seconds window blinks
Press Lap/Reset button once to make minutes blink
Cycle through minutes using Start/Stop Button
Part 2:
Press Lap/Reset button once again to make hours blink
Cycle through hours using Start/Stop Button
(for this part, it's a bit tricky. Hours can be displayed in AM, PM, or 24 hour duration. AM is represented by "A", PM is shown with "P" and 24 hour mode is shown with "H", so keep an eye in the seconds window when setting your hour so you know for sure if you have the right hour)
When your done setting minutes and hours, press mode button again till you get to main screen
A helpful hint is to remember when setting up anything in this watch, mode will cycle through the different screens, lap/reset will change the value of whatever your modifying (AKA minutes/hours) and start/stop scrolls through the different fields.
Hope this helps. Sorry if it's confusing, best I could do.
Sep 28, 2008 | Watches
Cannot turn off the Timer
Can you set the start/stop time to read 00:00? If so try that, it shouldn't go off at all. Another possible solution could be to turn it off and unplug it directly from the wall.... leave it for a minute or so, plug it back in and leave the timmer alone all together. If it has an internal memory, leaving it unplugged for a few minutes might reset the system. There might also be a main reset button hidden somewhere but you will have to look that up in the manual.
Jan 03, 2008 | Aiwa NSX-AJ20 CD Shelf System
Reser the call duration
go to the menu of all calls and empty the folder.
Dec 03, 2007 | LG Shine KE970 Cellular Phone
LG Shine KE970 Cellular Phone Logo
115 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
